thijsdebock
    8
Reputation
1 Neutral
Personal Information
  • Location
    Netherlands
Recent Profile Visitors
  1. I would say this tpic has def not been improved so far in 2023. As soon as you have filters on the summary it takes forever. even just chaning the name of a header title costs already 3 minutes
  2. Hi I am having issues with the automatically created truss end cross. When I turn the class of the truss off in a certain drawing, the automatically created truss end cross still stays visible in wireframe. Which is quite annoying, because it also affects the auto size of viewports. Are they atored in a specified class? or is there an option to turn them off? see attached screenshots for example
  3. Thanks Dave. Glad I finally know the workaround to get this feature happening. Good to hear it will be solved in the service pack 2, but for now I am helped with getting this feature working Thanks
  4. Hi Dave Its been a while, but I am still struggling with the same issue. See attached the pictures of the renders, you can see that the Panorama is still to heavily lit by ambient light, while all settings are the same. I also attached the VWX file for you to see. Hope you can find a misser on my end. cheers Thijs 20211011 VWX Test.vwx
  5. Hi Thanks for your answer. Before I send the file I need to strip all markings of the client first out of it. Rendering on cloud service I figured out that the 3D panorama only works out in a closed environement as soon if there is even a crack in wall the light from outside (even if its not there) kills the whole rendering. Which is still strange because if I use the same settings and angle on a normal renderworks camera I get a perfect render
  6. I have tried a lot of different options now but still getting the same bad result
  7. Hi all I am having a problem with my panorama 3D renders. For some reason the ambient light stays on and they wont be rendered in the perfect setting. Anyone has the same problem and or know a work around? This way the panorama is not perfect to be send out to my client Attached 2 screenshots of renders, one of a normal render which shows the result it should be and one screenshot of the panorama render. And yes this is after it is fully processed because i know it starts always as a openGL render Thanks in advance
  8. Hi. I am using the cloud publish with sotre on dropbox and proces on cloud, and have some sheet layers that I publish for processing into an image. I choose the option to render out of data content and choose the option export each page as single image. but it sometimes only publishes a part of the image and not the whole page. is this a bug or did more people had the same problem and found a work around?
