BJRobinson
    136
Everything posted by BJRobinson
  1. Thanks Pat. I had it on Show Snap others. Cheers
  2. Hi all. I have placed a pergola image from the resource manager onto the plan and I cannot select it. I am on the correct design layer. Any Ideas? Thanks in advance. Cheers Bernard
  3. Thanks Andy. Much appreciated. I probably would have found this if i had more experience. Cheers
  4. Hi Again. Sorry for the beginners questions. I have rotated a reference mark. However the text has rotated also. How do I get the text to stay upright? Cheers
  5. Sorry. I don't fully understand what you and MarkDD have said to do.
  6. I chose to trace the internal line of the wall. Offset it by 250mm, then offset it by 500mm the other way. Then drew a line to join these at either end, Compose them, then converted to polygon. I was hoping that there would be a quicker way. Thanks everyone for taking the time to reply. Cheers
  7. Thanks Guys I appreciate your replies. I decomposed one of the polygons. See first Pic. When I try to select the curved line, it just selects a small section. See second Pic. It always does this. So where to from here? Draw a new polyline over the old and offset it?
  8. I Have drawn some retaining walls as polygons. The client has changed their mind from rock clad, block walls to random rock walls. I want to increase the wall thickness from 250mm to 500mm. How would I do this? I have tried the offset tool. However it offsets it in both directions. Kind of works. However I then have to reshape one side back. I haven't used the wall tool yet. Still learning. Thanks.
  9. Thanks Kevin. Appreciate you taking the time to answer my question. I hadn't installed the add on. Doing it now. Cheers
  10. Hi. When I draw an object, say a rectangle or a line, I tab into the Object Info window next to it to type in the dimensions. After a while it stops working. When I tab into it it highlights the figure to be changed, however I cannot type over it. It stays the same. Only way I can change it is to finish the object and use the 'Object Info' pallet. Any suggestions please. Cheers
  11. Hi all. I Live in Lake Macquaire NSW Australia. I am newish to Vectorworks. I have over 35yrs of experience as a Landscape contractor and am now doing design. I am after someone teach me the best way to proceed. Show me the shortcuts and best ways to draw. I would prefer 3D as I am specialising in steep sites with multiple level changes and stairs. I can be reached through here or email me - info@rocksolidlandscapes.com.au Thanks
