Todd V.
    4
Reputation
2 Neutral
Personal Information
  • Location
    Denmark
Contact Info
  • Skype
    tverwers
Recent Profile Visitors
  1. I use grid lines in most projects for structural grids. Grid line labels within a file may not be duplicated for good reason. However, when adding grid lines to an existing sequence and attempting to edit the label value for chronological sequencing, I sometimes receive an error message "You have entered a label value that is already in use." My issue is that I cannot find the grid lines with that label anywhere in the file after checking all design layers, viewports, using custom selection, etc. Is there any way to locate a grid line with a specific label, or override a label, so that it can be deleted to allow proper sequencing of other grid lines? Thank you for any help.
  2. Yes, that would be the logical understanding, but I was unable to dock individual or grouped palettes to the application window without unchecking this option. I am on a Mac.
  3. After trying all above fixes without success, I tried unchecking "Floating palettes can dock to each other" under Palette Options. Then I was able to both dock palettes to the window and to each other while docked to window. VW2021
  4. After upgrading to VW 2018 SP1 from VW2017, my text input in title block data records in VW2017 files displays as vertical rows of letters (see attached). Please advise. Screen Shot 2017-10-19 at 19.08.25.pdf
