Ansons bay
  • Content Count
    9
Everything posted by Ansons bay
  1. Hi Im a designer and builder, dose anyone out there know if there is a simple survey product that I can go to site take levels, import into vector works and send back to the machine to mark out but and fills, and exact building locations with out having to go to survey school to use it. would a 3d scanner be best ........ be interested in everyones ideas. thanks A
  2. Hi rDesign Im not getting any joy, These are the steps I go through following the VW 2020 standard rotation in the help menu I select the object in 3d. select standard mode on the tool bar select orate tool select 1 corner of the object as soon as I select the other corner of the object the rotate tool disappears and the 3d object is deselected. should I be in wire frame ?
  3. Thanks for your help cheers A
  4. Hi, can anyone tell me where to find the 3d rotate tool, all I can find is the 2d rotate / rotate duplicate thanks Andrew
  5. Thanks Heaps........... don't know how i managed to do that............. now I know where to fix it.................. thanks again
  6. Hi all, My walls look different between my design layer and view port, in the view port it looks like they are not solid and you can see the joins. any ideas what I've done
  7. thanks Robert, will have to eat more carrots .............
  8. Ansons bay
    Font size
    Hi all, My eye site is slowly getting worse, is there a way to increase the font size in vector works so I don't need to wear glasses all the time. thanks Andrew
