575 -
Everything posted by Gadzooks
Library update - Summary
Gadzooks replied to AlanW's question in Wishlist - Feature and Content Requests
Agree! +++++ This is a peculiar way to update a service provision and as you say, there are plenty of ways to deliver the notification automatically - maybe in the form of an excel file or at least something searchable. Just a thought....Assuming this is routinely delivering an 'over-write' rather than an 'addition', maybe it's what gets withdrawn from the data we would also like to know about. Obviously if that was the case, pre-notification please! -
Hi Mattryan, Sounds like you need to chose a different way to view, as wireframe will always (as the name suggests) show only the structure (lattice) of the shape you have created - wether or not it has fill. What you've experienced is the difference between 2D and 3D. Try choosing OpenGL and try to work with that as your default. This will show solids as you wish them on layers. As you say you are in a VP, you will need to see the appropriate choice(s) in the OIP to achieve similar results. With your VP selected the shape details the options on the view you want. Looks like you have wireframe chosen as shown below. Choose Open GL instead.. Then choose to update as suggested.. Giving you.... Hope this helps.
There is the wall recess command. As it stands, its not the 'sharpest tool in the box', but like a lot of VW options it can be used for a work-around. Choose your wall and create a suitably shaped 3D solid to overlap the top - the main thing (for you) will be to make sure the underside surface is at your required angle. Also make sure it's longer than (overhangs) the section of wall you want to modify (assuming you want to modify the whole of the wall length). You are now here.. Now create your 'recessed wall feature' by selecting both and choosing AEC>Create Wall Recess.... Its nearly there! But (isn't there always a 'but')... Unfortunately the VW boffins have created the outcome for an endcap so even though the solid is longer than the wall it goes to its default position. Depending on the direction you have drawn the wall it will be the endpoint. I'm not sure why thats required as any attached (continuation) wall would have its own endcap at that junction (maybe @JimWcould comment/investigate?), and try as I might I can't see a work around for it. Maybe others can take this solution and move-on further - all I know is as soon as you start to try and clip that toenail off the wall it returns to generic solids - exactly what you don't want. Certainly one thing you could do is start with wall height and underside of the 3d solid at the same position for a cleaner result. This would reduce the overall height of the 'toenail' - but obviously still leaves with a small portion of endcap You will have to disguise that! Until someone improves this tool. Hope this helps. --------------------------------------------------- @JimWCould the endcap be taken out of the result of using this process on walls? As stated above, I'm not sure of its requirement. If it were able to be dropped, it would provide a nice way of forming certain features in walls. Does it need 'wishing'? Or is someone going to say - this is how you should have done it...
Thanks for the file - now I see what you mean. I thought you were having problems with your 2/3D symbols, but you're using the MEP tools. I'm not sure I can offer you much help on this. These tools have been part of VW for ages. I take the MEP toolset to be for MEP guys (but if you are in 'pipes and wires' you'll no doubt be using one of any number of extremely competent MEP 2/3D CAD software packages). For MEP use (I'm in architecture) I can't get along with this tool set - and it would be (only slightly) better if the 3D element was editable. As its not, you (we) are stuck with 'show 3D detail' that is not at all detailed. To retain your info (assuming you are making use of the record data) I suggest you build your own symbols with as much 3D detail as you wish and embed the 'receptacle', 'comm device', etc...that has the record and 2D info you want to retain. Tbh, by the time you've started that process you'll be thinking about ditching the MEP object and refining your own bespoke set of symbols with attached records and any other touches that will be useful. I use my own 2/3D symbols and add to them as required. My aim is to show 'design intent' to both client and later to the services consultant(s) who will overlay their more technical design. It would be interesting to hear from others about their use of MEP objects.
Mmmmm...interesting. Could you post a simple file to show an example. Just a quick piece of wall with some outlets/switches.
Just a thought - Have you changed any of the default colour settings that VW uses? If you look at Tools>Options>Vectorworks preferences and then choose the appearance settings... It offers colour choices for a wide range of actions/items.. You (or perhaps some other user) has changed the default opacity? ----------------------- Edit: Never having changed these options myself (why would you?), I've just tried this and not been able to recreate what you have. Sorry, this looked a solution.
Hi Christiaan - I'm sure this is going to turn out that I've not really understood your problem correctly, but you can adjust the texture mapping by the 20mm just by highlighting the wall and entering the adjustment on the OIP.
Feel the love. Its great when you see how this forum works and this thread shows it from start to finish.
Exactly - I'm unsure as well. I think (VW Inc are you listening?) the least I hope to get from the conference is who's in the seat now. I'm getting emails from both VW UK and from Exertis about 'their' conference. I've asked before (no response from VW Inc) , but could the new UK hierarchy be explained please.
VW 2018 Installation License / EDU->PRO
Gadzooks replied to Charlie Winter's topic in General Discussion
Just a stab in the dark - Something to do with whether you downloaded the correct software your serial number begins with? It'll be either E or the B,C or G option, and using the incorrect one will cause mixed problems. -
Yes there is. The information is shown in the OIP. Click on the VP to bring up the OIP.... It defaults to [drawing title] to suggest you might want to provide a better description, but to take all text out of this text box works equally well and will leave you with just the drawing number. and scale. This is also useful at VP creation as you have the same set of options offered. Assume this is what you wanted?
I have VSS (I know - there must be a cream for that). I've downloaded 2018 but, as I'm in that 'can I trust this on live projects' place, I continue to use 2017 atm. Whilst I'm using 2017, VSS is notifying me that 2018 is available. Very helpful, but now getting a little annoying. Yes - even though its just a click to dismiss, it disrupts concentration. My thanks to the helpful team at VSS, I realise its just a pleasantry, but can I suggest/ask.. Can the notification use a 'don't tell me again' checkbox? Why can't VSS check the records and see whether a certain user has already downloaded. And yes, I've thought the next bit through (just because you've downloaded you may not have got it up and running correctly). I have used it and I continue to 'test' my design workflow with it. So... Why can't VSS make a check from the VW 2018 activation records? As I said - Just a comment.
Where did my, back and rear views go?
Gadzooks replied to Kaare Baekgaard's topic in General Discussion
Haha - Just getting there myself -
Ok - (should have looked a little closer) Just seen you have multipane available in the dropdown - so you are on 2018 -
This sudden? Could you confirm which VW you are using please. (Would be helpful if you used a signature with this information in) -
Oval Tool - New Mode
Gadzooks replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
I like this! I'm upping it. VW innovates with headliners, but there are some times when just looking at the basic tool sets can provide better workflow for users. If there could be a subset of the oval tool that provides a 'half' mode that would be good also. -
VW 2018 (and VW2021 and VW2022): Push-pull tool problems continue
Gadzooks replied to line-weight's question in Known Issues
@line-weight I've just tried this file on an iMac and it doesn't show the dreaded beach balls. (Probably not what you wanted to hear) It seems the file is, as Kevin has confirmed (by having to take the whole thing to bits and redrawing!!), far too cumbersome due to the way you've had to import. Its not helped by wanting two of the same objects as well if you're going to split them - there might be mileage in the future to consider 1st, trying to reduce the faces as Kevin has done and then 2nd, opting for the use of symbols to help VW use (duplicate) the geometry at its most economic. Obviously symbols will only pay dividends the more there are. I have the same problem with these files. If I'm designing a complex building I don't want (say) a single imported wc pan to increase the file size so much as they seem to. I've just had this on a project and when I examined the 'helpful' BIM Object it was easier to redraw parts and smooth other parts. It made the geometry much more useable. TBH I'm not sure of the 'value' getting into bed with BIM Object has brought to VW. Perhaps @JimWor other could let us know how the future looks with BIM Object because, despite the fanfare, from my perspective the honeymoon is over and its not looking as rosy as the bride and groom had hoped? I'm obviously speaking as a disgruntled 'relative' that can't see it lasting I think the Brides father is fixing the brakes on the grooms car. Maybe its time to seek therapy on that one!! Definitely - 100% . This is useful therapy. I recommend a course - but is not going to come cheap is it Kevin! Some things I could offer that might help generally... Sometimes I've found it helpful (and often quicker than switching classes on and off etc) by quickly making the object you want to manipulate into a Group. Do what you want to it inside its 'own space' and then exit and ungroup. Also Ive found (and others may agree - or not!) that if you highlight the object first then use the PPT, VW seems to manage to disregard the geometry close by. On that one, all I can suggest is you might try it. -
@Max Eand @mike m oz Agree - Yes please. Placement and control thereafter is soooo clunky. Especially with roofs, but still affects walls. The creation of roofs and walls is very similar and so I assume the control of 'inserts' is coded quite similarly. Both walls and roofs could do with code refreshing the way 'inserts' are placed and I use the phrase 'inserts' as I think that doors and windows (and any other objects that pass through ) should be able to share and be bound together in the same aperture as most designers want this flexibility. To be able to grab and move to another position is intuitive and is preferable in many situations. Obviously I'm not advocating that the tighter control offered by 'height in wall' or 'above slab' is lost - just supplemented by a degree of freedom to move quickly to "what if I move it here - what if it was a bit narrower there......" That's what design is all about - perhaps more so in the initial design stages.
Good to know Rob. Would it be a step too far to confirm if some of the long standing issues that remain with doors/windows (unless your in Oz) may be sorted in next SP's.
- 12 replies
- vw2018
- catalogues
(and 1 more)
Tagged with:
(Edit: Thanks for the above. - I misread what I thought was a shadow line on your earlier shot.) Haha - well into it and, by the looks, enjoying your new toy. (You know that's going to leak don't you ) Just don't use the protractor!!..........We need you to be smiling still at the end of the day. In case you've not seen that... (Can't wait for your VW 2018 DAY 3)
This will inevitably hold you back. It gets the job done for the moment if you're under pressure, but when you have more time you'll find learning an extended skill set will reap rewards in your productive time. All the best for the learning curve. Don't be put off - with Vectorworks its not that steep before you are really happy with your creations. (Psst!, We're all learning still)
Drafting Aids - Line into Segments
Gadzooks replied to Kevin McAllister's question in Troubleshooting
Kevin - Yes, sometimes it takes a counter-intuitive direction. I too would want it to stay on the selected plane. Keeping your line in place, you can place the centre of your switches with snap set to 'distance' (fraction 1/3 chosen from options). -
As usual with your visuals - beautifully done Luis (never mind the quality - feel the width) And, I'll take a suit in the Shantung, a waistcoat in the Cotton Twill and can you do me a onesie in the Purple Polyester (for special occasions obviously !)
@Ellen 7This might help initially... https://youtu.be/1QTWwugRIV4 BTW - It would be good if you added a signature with details about the VW version etc so any future help could be more focussed.
Multiple Drawing Views - Weird Anomalies
Good catch Kevin. I hadn't seen this, but have now tried it and find it particularly annoying. Annoying in that I can't dismiss the protractor and (frankly) annoying that the swift comment from VW Inc via @Chih-Pinis effectively "yes we know". (But not stated) "But didn't want the issue to cloud the (big fanfare) multi-pane release." Pity, as I've used multi-pane in other cad programs for years and expected it to arrive on VW2018 'sweet'. I'd like to know if VW Inc would list all the other issues that they already know about (yes - like thats going to happen) and will be 'fixed' (caught up with) in the forthcoming SP releases. Would be nice though if there were at least some occasional posts from VW Inc in the 'Known Issues' section - It would be nice to show you're only human! Meanwhile we users will stumble over the issues, day to day, thinking that we ought to help our fellow users by reporting to this forum. --------------------------- Got that out of my system! Moving on - In my limited testing, (and here's me back to trying to help) it seems the 'feature' relates only to the next pane used. And also the tool can't be reselected after this event/occurrence. Seems its 'locked-out'. Just to add (so you can see I'm being fair!) - Generally VW2018 - from my use and reading of others use up to now - is stable and seems to lack any huge problems . And....yes folks, multi-pane is really good and will become second nature!
