Severn Clay-Youman
Content Count
8 -
Community Reputation
1 NeutralAbout Severn Clay-Youman
Rank
Greenhorn
Personal Information
Location
United States
Recent Profile Visitors
I'm trying to render a sectional perspective view using a perspective viewport of a Design Layer clip cube view. It works correctly with OpenGL, showing the geometry correctly cut away, but not with Custom Renderworks- it shows the 'uncut' geometry over the clip cube edges. It sounded from the teasers for VW2020 that it would work with other renderers besides wireframe and OpenGL- has anybody gotten this to work? Thank you, Severn
- 1 reply
- 1
Is Export HDRI Image broken?
Severn Clay-Youman replied to Severn Clay-Youman's question in Troubleshooting
Sheet layer rendering doesn't work - I'm curious, do you always render from the Design Layer? So much of my workflow depends on being able to re-render the exact same image as things change - I'm not sure how I would do it without the control of the Sheet Layer. HDR images (in other renderers) are nice because you have a bit more latitude to tweak exposure... -
That confirms a lot of my suspicions about Final Quality Renderworks, but it doesn't seem to solve the problem! -
I'm running VW 2019 with Renderworks- I'm trying to export a rendering to an HDRI file. The rendering mode is set to "Final Quality Renderworks", but VW still reports "This feature requires Fast, Final or Custom Renderworks. Set the view to one of these rendering modes to enable this feature." Is there a trick I am missing? Thank you, Severn
Renderworks textures unable to Receive Shadows in 2018
In follow-up, the file itself seems to have become corrupted somehow - I copied the assets into a fresh file and was able to render shadows correctly.- 1 reply
- renderworks
- 2018
(and 2 more)
Tagged with:
Severn Clay-Youman posted a question in Troubleshooting
I've run into a problem where I am unable to set Renderworks textures to "Receive Shadows" - the setting unchecks itself after I finish editing. This is pretty much a deal-breaker for a functional renderer - has anybody run into this, and found a workaround? I've also been having problems being unable to set bump textures in the Resource Manager.- 1 reply
- renderworks
- 2018
(and 2 more)
Tagged with:
Android NOMAD app seems to be stuck in "offline mode"
When I open up the Nomad app, it initially says "You are in offline mode", and my files don't show up - even though the device is connected to the internet. I'm not able to change preferences or anything in offline mode.
