ahenrie
8 -
Reputation
0 NeutralPersonal Information
Location
United States
Recent Profile Visitors
So for the 2018 Vectorworks after you make a viewport and put it on a sheet, there is a defaulted drawing label in the annotation. How do I change my setting so that the drawing label does not show up with ever new viewport I make?
- 3 replies
- drawing label
- viewport
(and 1 more)
Tagged with:
So I am in an X-Reference file of a plan with a door. In the original file, the door is in its own class and has the door tag on the schedule and the door tag is in a class of their own. I go to the X-Reference file to turn off the door and the door tag. The door turns off but the door tag stays on. How can I get door and window tags to turn off when they are in an x-reference file?
So I made elevation views of my projects. I have to manually update my view every time I make a change or ever time I open the file. Where in the setting can I have the file automatically update all of my views?
Overlapping items-How do you tab between the items
ahenrie replied to ahenrie's question in Troubleshooting
Say I have three different objects that are about the same size right on top of each other. I want to select the farthest third object in. what do I do? I can not get it to highlight. I do not want to bring the third item forwards. -
So if I have items overlapping on top of each other. How do I tab between them to highlight the one item I do want?
CLT C an item then moving the item on the x or y axis
thank you -
So after I hit Ctrl C to copy an item, I then hold down the Ctrl and hit Shift key to move the item on the x or y-axis but the whole item moves instead of the copied item. how can I just move the copied item?
