joestewart4669
24 -
Posts posted by joestewart4669
You are amazing. Thanks so much!
Hi,
Am I using the wonderful script you sent correctly as it doesn't seem to work in VP annotations?
Many thanks
Joe
On 2/20/2018 at 9:16 PM, AlanW said:
Hi, Its a shame that the AUS/NZ fence tool hasn't been incorporated into the full VW rollout, it allows send to surface.
Also is attached a Marionette file that sends a fence to a terrain may assist in the interim.
Hi Alan, Thanks for sharing the file. How do I use this with the railing/fence tool please?
Hello I cant run the script as only this file is in zip folder. 'Clear Print Setting.txt'
Not 'Clear Print Settings.vss VectorScript'
Please re-send the .vss file.
Many thanks in advance
Hi Boh,
This is so very kind of you. Thanks.
Im going to have a play around and try and figure it all out which Im sure I will be able to now. I'll come back to if I have any problems.
Thanks again
Joe
Hi again,
I think I should add some more to my post above to explain further.
I cant figure out where the worksheet I pulling the text from. When I click on the database header for Column A / Note the fields are blank and I cant relink it as there is no ' Text option in the records of callouts. I have the same for Columns C, D, E, F, G, S, T, W, AA, AF and AG Please see attached screen grab.
Ive tried opening it with VWX 2020 and 21 but to no avail.Im no expert on this so apologies if I am missing something obvious.
One more question if I can be so cheeky, how do you create a custom column in a database row so I can enter my own text alongside database information?
Many thanks in advance.Joe
Hi Boh,
Your HOUSEKEEP worksheet is absolutely brilliant.
I don't suppose you have one for VWX 2023 as I think some of the functionality has been lost when opening the one you kindly shared. Maybe not but I'd like to check if possible.
Many thanks
Joe
HI Iskra,
Thats amazing I had no idea !
Thanks so much!
Regards
- 1
Hi Dave
Thanks for yours.
I should have mentioned that I don't have VSS anymore. Sorry.
Regards
Joe
Hi there,
How do I email the exported to panorama file to a client?
Ive tried adding the java, jpg and html file but im not allowed to attach a Java file.
Any help appreciated.
HI Iskra,
I trust this finds you well.
Whats is best practice for sharing Panormas with clients when you do not have VSS please?
I ask as I cant attach java script files to an email. If I then send only the .jpg and .html file it opens a blank browser page when the html file is clicked.
In addition, to make the panorama work locally on safari I had to enable developer mode. (as per the instruction for web view files I found on the forum). This is not an ideal workflow for a client that I am trying to impress. Do you know of a cleaner way please?
Regards
Joe
Nikolay!
That is amazing!
Thanks so much!
It works a treat!
I wish I could learn how to do that !
Best Regards
Joe
Hi all,
Does anyone know of a way to add all selected dimensions to calculate their total length?
Ive been looking at Marionette as a possible option but no dice so far!
Many thanks
Thanks Boh,
Its not that they are different it is that they are not in numerical order.
They are in Numerical order in the navigation palette.
Update.
I have managed to get them in Numerical order by ensuring that a folder is not 'Selected' and also that drawings are 'Loaded'
Thanks
- 1
Love that you PS'ed this to explain.
I totally agree btw. Such odd positioning.
Can anyone help me with the Project Revision History worksheet please. The order of the sheets is very odd and I cant find a way to reorder them??
See attached to see the current order on the work sheet and the order in Sheet Selection.
Bizarrely the GA plans have reorder correctly while I've been fiddling with it but the sections are still in the wrong order.
Either Its very glitchy or im missing something.
There is also very little in the help on this subject which is shame as its quite powerful.
Also how do I revert to no folder selected once 'Show Files in Folder' has been selected. I think may be causing the problem but no way to change it back.
Thanks in advance if you can help.
Hi James
I think the Title Block manger and Project Issue/Revision History and Sheet revision Log could help you as it will display all you revisions and Issues.
Brilliant thanks guys. Will try tonight.
Thanks Line-weight.When you say 'snap' do you mean move away then ensure that when I move back the snap tool is on?
Hi Tom, thanks for replying. yes that does help for surface hatches alignment but frustratingly not for removing said line.
Hello all,
So what I want is to set up class mapping so that when I receive a updated survey DWG I can quickly map the survey classes to my classes.
Ideally there is a video on this topic but I cant find one.
Regards
Joe
The Mobius Curve Thing
in General Discussion
Posted
Hi all,
stumbled across this looking how to model a mobius strip.
I’ve come across this which is interesting http://demonstrations.wolfram.com/MoebiusStripAsAHalfTwistedSquareTorus/
Also I’ve attempted to create a mobius using the subdivision primitive. Anyone else had any luck with that. ?
