neither command works on this shape
extrude fails to extrude polygon correctly, and ONLY extrudes sides (as opposed to extruding polygon plane)
drape doesn't work at all...
Furthermore, the shape I need would entail sloping down the spiral at the broader end... how would you do such a shape???
any suggestions?
thx!
using VW17 w/ latest SP 1.
when I render realistic exterior fast with edges option I get edges significantly offset from where they should be... this happened before the SP1 as well
anyone else aware of this? see attached
This is a bug, pls advise, respond.
