145 -
Posts posted by Rishie
Thank you Matt. I am waiting for that improved version
Thank you Mr.Alan
But shutter is designed to close the window in india. How can i make it close any possible way atleased to show it as closed
How can i join the components in slab?????
I created a window with all my preferences but at lost when i placed it and showed open 3D the Muntins is opening but not my exterior shutter or my interior shutter.
I want my muntins to remain closed and control the open and close property of shutter???is it possible
Working 100% thnk you
Thank you Matt i failed to create a 2D symbol for it so its not visible, now its perfect.
But i cannot give different texture for post like in leaf for doors, as railing post is assigned to a class only one texture for the entire post is possible is there any way to give some additional texture for it????
Hi Matt,
When i restarted my machine it showed to me in Railing setting, actually my system configuration is low may be because that it is slow.
Thank you.
How to create custom post for railing????
Most of the default custom post that are in vectorworks is not readily available in India, I created post and exported to that default location but its not showing in post profile drop down box in railing tool.
Thank you markul for you reply
But zoom line thickness had not checked in vectorworks preferences display tag and more over if you check in my screen shot (Second image i had attached),
The plaster thickness and line weight is same for slab and wall but while exporting its totally different
Thank you jonathan for your reply
But jonathan is there any function to join the component between the slab and wall
If i use plaster for wall and slab how to use component join and join them both?????
And why my exported image file is not showing the patterns and line weight i have used accurately and clearly???
Hi guys
I have been inspired of the Vectorworks slab components but i have few doubts regarding that let me list my queries
I attached image of my project
1)How to connect the components for my wall and slab?
2)What is datum in slab and its top and bottom component?
3)When i am exporting my project as image file although i am using high resolution and quality to very high, the line weight and the pattern which i used is not visible.
Below i attached two image the first one is the exported image and the next is screenshot there is lot of difference between both
Thank you Alan its very clear
Quote
Thank you, Alan and Kevin
this works good in circle and rectangle but if it is regular hexagon and circle it creates a weird shape and as Alan said it tried to double click and edit one profile but it very diff cut to get a prefect shape
can you give a video or any advice how to rotate and edit a profile a get a prefect shape
Thank you.
this will be very useful to me
How to create different nosing style for stair and different leaf for door
change insertion point for a symbol
in Architecture
Posted
How to change insertion point for a symbol?
for a 2D, 3D and hybrid symbol.
