mike m oz
4,878 -
Posts posted by mike m oz
Architects and designers are graphic oriented people and and the interface needs to reflect that. UI improvements that make the program easier to understand and use will improve the appeal of the program to them and make it easier for new users to learn and understand the program. That will benefit all of us.
- 3
This part of the Keynote left me wanting more. More information on these interface improvements and please include them in the next version.
Try hitting the Return Key on your keyboard.
Good lateral thinking Kevin.
Rob, both are needed in 2D and 3D
Bicycles are a higher priority than motorcycles though.
- 2
I tried a quarter sweep but the bend wouldn't convert to a subdivision object.
I also tried lofting with a rail from two objects that had the same shape and it also wouldn't work. ie. from one with two very short vertical straight line segments (1 mm) to one with longer vertical straight line segments (100 mm).
There must be a way to do it. Hopefully the Vw Inc. experts can explain how to do that. Also from a rectangle to a duct shape of that type.
I tried that Kevin and a simple loft does work. That doesn't gve the swept result that Lee is after though. To do that you need a rail and I can't get the loft to work with a rail curve.
I suspect the problem is because of the two extra segments in the second curve. In my experience lofts are problematic when you have curves with different numbers of segments.
Lee may have to look at doing this with a Subdivision object.
Can you please post a file with your two nurbs objects in it.
I like the mock up generally.
I prefer the colourful icons for resource types though rather than grey subdued.
The 2D components for Hybrid Objects feature movie should clarify it for you:
https://www.vectorworks.net/en/architect/features
Also have a look at Help: Concept: 2D Components for Symbol Definitions and Plug-in Objects
Try exporting each 3D layer separately so they can import them one by one and assemble the model manually.
Quote
The marketing material has the VW interface I want again this year 🙂
I'm with Kevin on this one. An interface that looks like and works like it does in the promotional videos would be a real winner.
- 3
Will, you can do this with Tile fills.
For more information look at Help. There is a sub-section in Basic Techniques titled Using Tile Fills.
I would still like to see a more visual way to define hatches though as per your Wish.
No and it is unlikely that there is one.
The Industry versions of Vectorworks: Architect, Landmark, Spotlight and Designer can import Sketchup files. Fundamentals doesn't have that capability.
Pammv, use page based symbols for electrical. They will then be the same size no matter what the scale of the Viewport is or the scale of the Design Layer.
It is an option within the Symbol Options edit choices in the Resource Browser. If you are going to change the option for existing Symbols make sure you are in a 1:1 scale Layer when you do it.
Apologies M5D. I missed the gist of your original post by not reading it carefully enough. Hopefully the Vw Inc people will be able to give you an answer.
Rather than building the slab from three components try making it a single component slab and subtract the bottom recesses.
Do you get the same result if you use the Subtract 3D Object From Slab command instead of using Solid Subtraction?
Try trashing the Vectorworks User folder first. If that doesn't work then try reinstalling.
Delete the 'clean my mac' program from your Mac and never be tempted to use it again.
- 1
- Full height single component slab (in this instance 172 thick)
- Create a tapered extrude of portion(s) to be removed (in this instance 72 high with taper at 45°)
- Align bottom of slab and tapered extrude(s).
- Select slab and tapered extrudes(s) and use Subtract 3D Object From Slab command (AEC menu).
- 2
Vectorworks User Interface Overhaul
Posted
For me the colours are a visual cue and a monochrome look does not appeal to me at all.
