mike m oz
4,879 -
Posts posted by mike m oz
G-Pang
The capability doesn't exist unfortunately - I wish it did.
How I overcome it is to:
- Draw a wall across the end as for the exterior component (eg 110 bwk) making it longer than the joining wall width.
- Make a T wall join.
- Stretch both ends of the end wall so that its length exactly matches the joining wall width.
It is something I only do at working drawing stage when I am trying to make the walls look correct. It is better not to do it at the design modelling stage as it complicates things too much and introduces additional lines which have to be dealt with in section and elevation views )particularly when these are converted to lines).
There is also the quick and dirty option of drawing a 2D filler polygon with no line thickness over the cavity to simulate the outer skin returning. This method usually requires a bit of tweaking to get it right
In the Oz (Australian) version it is located under the Text tool
As a guess your version will be the same.
TAD
The Wall Tool is part of VectorWorks Basic. It provides all of the wall tool functiionality, but the user has to create the cavities (these should really be called components) that make up the construction of the wall when it is viewed in 2D.
The Wall Type Tool comes with Architect and allows you to create and save preset wall types (ie. overall width and individual width of the components which make up the wall). These wall types can then be easily recalled saving you the bother of having to recreate them each time you want to use them. They can also be preset to be a particular class, have a particular height and have records attached to them.
All of the latter can also be done with the 'manual' Wall Tool. The Wall Type Tool simply 'automates' some of these functions allowing you to work more quickly and effectively. You will probably still have to think through what it is you are trying to do and either alter the existing preset wall types, or create new ones.
My experience is that new users have problems with the Wall Tool because of the way the wall components (aka cavities) have to be formed relative to the centreline of the wall. It really would be beneficial if NNA were to standardise the method of wall creation across both tools. VW Basic could require you to create each wall type as you require it, like now, and VW Architect could allow you to save the wall types for later re-use.
What also would be nice would be the ability to reshape floors using the polygon reshape tool as you can with roof objects.
As show other objects while in groups does not work for floors (or extrusions) this would overcome the issue of not being able to see other objects whilst you are making the changes to floors.
MJW
Don't dismiss training so lightly. The program is constantly evolving so the need for training is continuous, whether it be self training or formal training. There is a continuing need to come to grips with new features and ways of doing things as they are added.
Even though I have been using the program for 11.5 years I wouldn't pretend to know everything. I have learnt from the other sources I have mentioned, and expect to continue to do so.
Think of training as an investment which will enhance your capability and make you more productive. It may also help to diminish your obvious frustrations.
Contact your UK distributor and ask them what training is available and who does it where. In a brief search of the internet I found some UK training resources.
This was covered in an earlier post by another user that I can just recall.
It was suggested that for each Viewport you create separate light source(s) in the model with separate classes so that the correct light source(s) could be 'switched on' in the viewport. Hence each elevation view could have its shading in a consistant direction.
I thought it was a very good lateral thinking solution and I am grateful to the person who thought of it.
MJW A couple of points.
1. The NNA manuals are far from useless. They are well setout and explain stuff in plain English. In my experience many other CAD programs manuals are no where near as good.
2. NNA provide free technical support for 18 months after purchase. Other programs do not offer anything like this level of free support. With AutoCAD for example you will have to pay each and every time you contact their support people.
3. There is also no other CAD program that I am aware of that has a public techboard like this one. NNA are very receptive to feedback and often technical queries are answered by either them or the contributor's to the technical board.
I have provided VW support and training for many years, and my experience is that for many users it is easier to ring or email than to bother looking for the answer either in the manuals or the on-line help. I've even had people state that "They don't do manuals", or similar. For me this is sheer stupidity - RTFM has a lot going for it and can reduce frustration levels substantially. Try it for a change - you might be surprised at how easy it is to find the answer to your queries or problems.
Katie is dead right when she says there is no substitute for training. Invest in some - whether it be formal lessons, the NNA training CD's, the ArchonCAD training manuals, the OzCAD multimedia CD, the third party books etc. Gaining an understanding of the concepts of the program is critical to becoming proficient. Training will help you do this.
If you also develop an an attitude of learning as much about the program as possible, and adopt a mindset of solving your own problems, you will get much more joy out of your work.
Eric
Training suggestions:
- The OzCAD multimedia CD by Julian Carr (very good).
- The ArchonCAD training manuals.
- The Janis Kent Works Manual (if it is still available).
I have also found the current NNA training CD's to be very good. They are for version 11 though - it might be worth asking them if the earlier version Training CD's are still available.
Dan
That must be a new feature because in 11.01 it doesn't.
All it shows is a black dot against the current class.
Chris's need for data is all part of the BIM concept.
That is having created the model for it to be truly useful under the BIM paradigm the model must return accurate data which can translate into accurate costings.
For me however I am more interested in the appearance and issues like representing building reality as close as possible. Some examples:
- Being able to have different appearance attributes for the top, bottom and side surfaces of floors.
- Having the capability to return both the exterior and interior wall finishes separately into the reveals of door and window openings (we don't use timber reveal linings internally - the wall finish wraps in)
- Having the capability to add slab thickenings (with 45? edges) to slabs on ground (both to the perimeter and under internal walls).
- Having the capability to add integral beams to the underside of slabs.
- Having a 3D ceiling tool which will create suspended ceilings of different types.
- Being able to simply add cornices and skirtings to walls (having them return into reveal openings where appropriate would be great, but I suspect this is too difficult).
With some of this I am thinking forward to where we want to be - ie. producing accurate useful and useable 'live sections'.
On this issue it would be nice if the 'architectural live sectioning' had a depth of field capability. By this I mean the capability to choose how much of the model is seen beyond the cutting plane ranging from nothing (ie just the section) to all of the model beyond. The cutting plane should also have the capability to be stepped in plan.
Eric
Check out Custom Tool/Attribute under the Organise menu.
- Create the wall the way you want it,
- Draw a piece of wall and leave it selected and the Wall tool active.
- Select Custom Tool/Attribute under the organise menu.
- Select the Attributes you want.
- Click OK
- Save the script with a name that appropriately describes the wall type.
This will create a Script pallette (give it a name such as Wall Types) attached to your drawing which can be called up through the Window menu. Just double click on the Script name in the pallette and it will bring up the Wall tool and wall type for the script so that you can draw the wall.
Other wall types can be added to this Script pallette by repeating the above process.
This Script pallette can then be imported into other drawings. I would suggesting importing it into a new drawing based on your Termplate drawing and then saving this as a new Template file (overwriting the old one) so it is there for all new jobs.
It would probably be prudent to read the relevent section in the manual first so that you have an understanding of what you are doing before you tackle it.
This process is pretty simple really, and can be used for all sorts of presets for tools such as wall types, text types, line types etc.
All it does is write a small macro program that you invoke by double clicking on it. The capability has been around for ever, but as the program has become more sophisticated the need for most users has diminished. Check it out but because it provides a very quick way of automating activities,.
PS for one offs you can transfer wall cavities from one wall to another using the Eyedropper tool. One proviso though - it is only effective when the walls are the same width. I usually use solid walls at the design stage and then convert these walls to cavity walls at the documentation phase by selecting all of the walls and using the eyedropper to change their attributes. Using different classes for each wall type makes life a bit easier here.
Alanmac
What I was having a dig at was the implied suggestion in Sofia Ames' original post that to be bona fide one had to use Studio Pro or Viz, and that those of us who choose to do otherwise are Phillistines.
There are many ways of doing things, and we need to make decisions on our needs not on what others think we should do. ie. fitness for purpose.
Most of us in the VW community will have had the experience of being criticised by AutoCAD users because we dare to be different. Choosing AutoCAD because it is 'the supposed industry standard' is not always the wisest choice.
Hence the imploring to not be a sheep and follow the masses. No insult to anyone was intended, and I apologise if anyone did take this the wrong way.
Alanmac
I will give an example to explain why. Consider a first floor slab:
- On the top it may need to have a tiled, timber or carpeted floor finish.
- On the underside it needs to have a plastered finish to simulate its role as a ceiling.
- The sides will be exposed in stairwell openings and/or balcony situations. In both cases it will probably not be finished as for the floor above or the ceiling below.
Hence the need for 3 separate surface finishes.
I will qualify this by saying that here in Australia we tend to build with concrete floor slabs, and in domestic work the slab soffit is usually the ceiling for the floor below.
To overcome the issue I have occassionally resorted to using two layers of floor slabs for each floor of the building.
- The first floor is the structural slab which I finish as for the ceiling below.
- On top of this I then place floor finish slabs to obtain the correct floor finishes for various rooms / spaces in the model.
it is a bit time consuming but it works.
Katie
You people should not be sitting on your backsides 'hoping' that Apple will fix the problem with Tiger.
If Apple will not commit to fixing the problem then NNA must! To not do so would be commercial suicide.
This is a real issue which needs to be addressed immediately. If NNA, with its Apple user base, cannot get Apple to realise ithe gravity of this problem then you have to solve the problem yourselves. If this means developing and/or buying your own printer drivers then do it.
This is like the issue with the OIP delay which Apple won't guarantee to fix - we users don't care what the problem is we just want it fixed.
The ball is in your court NNA! Deal with it.
[ 12-19-2004, 04:43 AM: Message edited by: mike m oz ]
I have attended a Revit demonstration and it is impressive. They were however a bit reluctant to discuss certain aspects, and to show us how it would deal with particular problems.
An associate who attended the same demonstration decided to run with Revit. After 3 months he is still struggling to come to grips with the program, and is frustrated about how he is going to fill in the missing information.
I have seen a set of his drawings for an addition to an existing house and they are not easy to read or attractive. The exact opposite of his manual drawings that I have seen in the past.
I think the big point to be made is to not underestimate the learning curve on what is a quite complex problem. It will be a major paradigm shift as you will have no option but to model in 3D. Many people don't fully understand the implications of this.
Those people who can't adequately think in 3D and / or discipline themselves in how they tackle projects will get themselves into a serious mess very quickly.
Good luck to them in whatever they choose to do.
It would be useful if floors could adopt the hole forming functionality of roofs. ie. the way in which you can cut holes in roofs by just placing a polygon into the "roof group". Cutting holes in floor slabs would be a lot easier if it could be done the same way.
Another nice feature would be the ability to resize the floor polygon inwards or outwards by a one click method, rather than having to create a new polygon using the offset tool and then deleting the original polygon. This would allow the source polygon to be generated by the walls and then this polygon could be easily resized to get the right relationship to the walls.
The other necessary floor improvement which is required (and has often been mentioned before) is the ability to apply different textures to the top, bottom and side surfaces of the floor slabs.
The problem with using export lineweights by colour is muddied by the fact that very few AutoCAD people stick to the program defaults for the colours.
Therefore for an export of this type to be useful to the recipient you MUST know the protocol of the recipient.
When you are exporting for more than one recipient the likelihood is not all will be happy, unless you do individual exports for each.
[ 12-18-2004, 10:12 PM: Message edited by: mike m oz ]
Sometimes the autojoin (and manual join for that matter) does not work properly.
What you need to do is:
- heal the walls.
- stretch the joining wall back from the other wall.
- use the cavity join mode instead.
A pain!
Information for the Oz/NZ architect users only.
The camera tool is located on the Architect tool pallette - 3rd from the bottom.
It is a very useful tool which allows you to place the camera in the 2D view - therefore enabling you to set the correct height and distance in relation to your model for the camera shot you have taken, or the view you desire.
To call up the 3D view all you do is click the appropriate box in the OIP and voila.
Very clever stuff courtesy of Julian Carr.
Katie
The only problem with postscript files is that they are quite large and if your internet provider has an email attachment limit (mine has one of 5Mb - some are lower) then they can't be emailed.
PDF is a much better option - the file sizes are small and everyone can read them.
I have used PDF successfully for some 6 years with vey few problems, apart from with plan printing bureaus where they tend to have machines that allow few options for input, and they don't want to accommodate something different.
A suggestion NNA
Please modify the object info routines so that you can include a checkbox in the OIP that allows the user to see the information in sensible units like feet or metres.
For us metric users (95% of the world's population) the OIP currently returns numbers which are nigh on unreadable.
Being able to have a check box so that the areas can be returned as sq metres, and the volumes as cubic metres, would be a real boon. I'm sure even your USA users would appreciate being able to nominate the units as being sq ft and cu ft respectively.
And while we are about it can you also please produce a version for the rest of the world that has metric units as the default units, rather than feet and inches.
For most of the people in the world feet and inches are about as relevant and understandable as ancient Egyptian cubits. Even in countries with English colonial heritage, like Australia, most people under 45 don't have a comprehension of feet and inches. To them it is just ancient history.
I did read somewhere once that you in the USA committed to adopting the metric system back in the 1800s, and you still haven't done it. How about getting on with it - it really isn't that hard and the benefits are enormous. Australia converted to the metric system in the early 70's - it took just 3 years from start to finish!
Why do we have to wait for Tiger for this problem to be fixed.
NNA should be pressuring Apple to fix it now.
A lot of the pleasure of using this program has gone on the MAC platform. The innacurate 2D snapping to objects makes tasks like dimensioning a tedious chore where once it was relatively straightforward. Dimensions regularly come up wrong because they haven't snapped properly, and the snapping of dimensions to other dimensions just doesn't work at all.
Productivity is shot to hell and the frustration levels are extremely high.
I don't care what the problem is I just want it fixed!
[ 12-09-2004, 09:35 AM: Message edited by: mike m oz ]
I second archoncad's recommendation
Check out WinDoor 11 available from OzCAD in Sydney.
It will do all you want and much much more:
- Fully editable parametric objects (ie., user controlled parameters).
- Door styles include flush, half glazed, glazed, panelled and louvred, as well as glass doors with square or splayed rails or patch plates. Any door style can be used with any door type.
- Door types include hinged, pivot, sliding, cavity sliding (pocket), multi-track sliding, bi-fold and folding. Any door type can be used with any door style.
- Window styles include fixed glass, fixed sash, awning hung, double hung, sashless double hung, cottage double hung, casement, sliding, louvred and glass block.
- Window types include straight, bay, bow, corner and round.
- Doors and windows can be combined with an almost unlimited range of possibilities.
- Two different styles of glazing bars (muntins) are available for both doors and windows.
- Many different styles of masonry sills can be created as part of the window or door unit.
- Support for brick header courses above door or window openings.
- Extensive control over internal and external trim.
- Sloping, gable and curved heads with user defined radius.
- Door hardware that includes symbol-based user defined objects.
Once you start using it you will hardly use the NNA door and Window PIO's again. About the only thing it doesn't do is overhead doors.
Movie Download Problem
in General Discussion
Posted
Don
I had similar problems - in the end I concluded it was because I had a 56K dial up connection.
I had a friend download it for me with his broadband connection and he had no problems at all.
The other issue is that the download contains 2 files - a quicktime movie file and a PDF file. It might become simpler if NNA made these 2 files seperatlyly downloadable.
