alanf
Content Count
10 -
Community Reputation
4 NeutralAbout alanf
Rank
Greenhorn
Personal Information
Occupation
3D Set Designer + Illustrator
Homepage
www.misterbananapants.com
Location
United States
Recent Profile Visitors
Hi all, Is it possible to use either: 1. Python Scripts (.py files) that were created for Rhino? 2. Use Macros somehow from Rhino (assuming this is a hard "no") Thanks
For others following this, I figured out that in order to "add the new command", you should see a group in the tree called "Miscellaneous" on the left window. The new Menu item you created will be inside that group. In the attached image, I copied my new "Isolate" Command to my new "AMF" Menu. EDIT: And then if you want, you can go into Plugin Manager > Edit Definition > ...New, and create your own name for that new group in the Workspace Editor, instead of it using "Miscellaneous"... And you'll end up with something like this in the Workspace Editor... (Notice "Miscellaneous" is no longer there) ***BTW, sorry if I'm continuing this in the maybe the wrong thread? Please feel free to move it or ask me to, etc.
Thanks so much, @Pat Stanford! Will give it a go! @Pat Stanford How would I make a script into a Menu item, and then create a shortcut/hotkey? I see how to "create a new menu" in the Workspace Editor, but not how to bring my "Hide Unselected" script into the Menu? Would greatly appreciate a hand with this, thanks! (And thanks to @Bob H for the Script info!)
Sorry, follow-up question: How do I bring your script into another file? Thanks so much
Michael, You're a damned genius. Awesome script. Thank you.
Thanks so much, Michael! Looking forward to trying it out!
Hi Michael, Where would i find the Cabinet scripts you wrote about? Would LOVE to try them out! Thanks Alan
Hey all, Is there a way to change the font sizes of the interface? (i.e. menus, tools, dropdowns, OIP, etc.) I just got a 4K monitor, which is great in some ways visually, but it's helpful if I can make the interface/system text larger. Sincerely, Getting Old and Can't See the Text
Hi, new to using marionette. Cool script,but should my computer be spinning-wheel-of-death every time I change info in OIP? Take a good 20+ seconds to make each change.... Thx
