tismacfan2
86 -
Posts posted by tismacfan2
Thank you for the answer. It is mainly in the vectorworks 2018 SP 6 where I have the problem, while only 1 drawing is open. But then everything goes very slow, selecting, moving, until the only solution is to close the program, empty the cache and restart, then I can usually work again for half an hour, but then you feel it slowing down considerably. I work with the Dutch version, so SP3 for 2019 is not yet available. But it is frustrating to have to work that way.
What is that with the memory, speed of vectorworks 2018 and 2019 on a mac?
I notice that as I work with vectorworks the program gets slower and slower. Sometimes I get the message that I am out of memory, while I have 24GB of memory. When I close Vectorworks after a long look on a rotating beach ball and restart it goes very smoothly for a while. Someone also solve that problem and how. -
I don't use the script in 2019 but in 2018. And there is get the message comma expected for every class in the document.
Pascal
Hello
I try to use this script. But when I selected the script and click in my drawing, I always get the message "comma expected"
When there are 2 classes and I click twice on OK I get the sheet with the tings I need. But when there hundred of classes than I have to click as many times as there are
classes. I think I don't use it on the right way. Mayby you can give me a tip how to work with it
Thanks
Pascal
Thank You Pat
works Perfect
Pascal
Could someone help me with a script, which moves a selected object to the active class.
Thank you Pascal
I have a workdoc. in my teamwork. This evening I want to save and commit to my project file. But I always get a window for replace a wall style. He want to replace and existing wall style always in the same wallstyle. I can not push the annulation button only the OK button is available. Problem is every time and I click maybe 100 Time the OK button but gets always the same window. Anyone know what the problem her is and how ik can solved it?
Thank you for the feedback
ok I find the problem, with the help by DrelARCH. It is like you said. When you are one active class with a opacity lower than 100%; it comes a kind of gray. When you change the class with opacity 100% and you edit the wall everything is coming just fine
Thanks for the hint
Pascal
thank you and how do you reset a thumbnail please?
I choose for edit the wall style and than choose everything by class but nothing change
thanks
Pascal
if you draw walls with components, you can later in your spreadsheet the quantities on the basis of this component. However, if you remove this wall from your drawing, you will no longer be able to select the component even if the wall is still in your resources. That way you can not make a template spreadsheet. It would be better if you could select all the components of the walls that are in your auxiliary sources instead of just the components that are drawn in your drawing. Or is there an other way to do this.
Pascal
yes indeed that is the same problem? Question is when will it be solved by Vectorworks, because in this way I can't use VW 2019. it is a bit regrettable, that you get a lot of
new features in a new version of Vectorworks but the old things stop with working. Hope I get an answer when this bug will be fixed.
Pascal
Hello
I have the following problem. I draw a building level 0.? Than I make a viewport from level 0 and put this on my level -1. By this way I can control the classes in the viewports and make my walls from level 0 visible with other attributes so I don't give a color to the wall and the linetype dashed. In this way when I make changes in my level 0, it will be updated in my level -1
But when I make a section on that building, I see all the walls from my level 0 in my level -1 even when I put the classes from my viewport from the level 0 on hidden?
Is this an known problem, I didn't have this problem in VW 2018. and the drawing I talk about is convert from 2018 to 2019
I hope my question is clear for everyone
Pascal
Can anybody tell me how I make a space object style from scratch?
Can I find somewhere a video to make this
thanks
Pascal
maybe they should make it possible to choose a class in the settings of the border.
Pascal
- 1
When I place a sheet border it is always drawing in the active class.
Is there a possibility to draw it in a pre choose class?
thanks
Pascal
Hello
In Belgian we have an own window tool, but there are problems with tis tool when I used it as a cornerwindow, specially when it is een inside cornerSee fig 1 & 2. In 2d is the presentation OK, but when I switch to a 3d view, is the wall disappeared en I only see the window. When I in the 3d view delete the window
than I see te wall back.
If I use the American version of the window is everything ok but is there a possibility to set the window behind the exterior wall as in fig 3
What should be the settings if I want this
Thanks for the support
Pascal
Thanks for the answer, but that is just the problem. I can choose top, bottom en sides. So he always take the both size. But I need for example the leftside in red en the rightside
in bleu. So should there be another sollution?
Thanks
Pascal
Hello
I have a drawn a slab wich I use as a covering stone. I can render these slab in the same texture, but that is not the effect I want.
I'd like the top en one side in a texture, the other side must be a other texture because there must be a different between the inside and the outside of my slab;
But can anyone give me a tip how to do this. Because when I look in the render settings I just can change te top and de Both sides of the slab.
Thanks voor de tip
Pascal
Do you mean = CONCAT ('Title Block Project Data'. 'Bouwheer', ' ', 'Title Block Project Data'. 'Bouwheer adres') this?
Pascal
Nikolay,
Thank you, I try if it will works by me. But a little other questions. how can I put two results in one cel
i want ='Title Block Project Data'.'bouwheer' and ='Title Block Project Data'.'bouwheer adres' (text in bold) in the same cel
thank You
Pascal
slow going Vectorworks
in Troubleshooting
Posted
Yes there is also a Dutch version of Vectorworks. Designexpress is the distributor for Belgium and the Netherlands. I work with MacOs Mojave, and there are no antivirus programs running on the mac. CleanmymacX. And I usually get the message that I am running out of memory. I also feel the longer you work with VW the more the cach files increase,
