2,816 -
Everything posted by Bruce Kieffer
I know about the window shade hiding the records in the Data tab of the OIP. That got me again yesterday! But I still have no idea where the OIP settings are that @martinmiles refers to.
Worksheet Set Criteria and Edit Criteria?
Bruce Kieffer replied to Bruce Kieffer's topic in General Discussion
Maybe having a "Clear All" in Edit Criteria is a more understandable solution? I get what you are saying. I've played with it, and looks to me like once you've set some criteria, then set criteria basically clears all the previous settings. -
What's the difference between worksheet Set Criteria and Edit Criteria? As far as I can tell they do the same thing.
Well, I found others asking this same question, and the answer is NO. There's a wish list item for it from a while ago, and I upvoted that. In the meantime I did this even though it is no where near as good as a hyperlink would be.
Where are the OIP settings?
Is there a way to add a clickable link to a record text? I want to be able to click the WWExpress text and go to the web page to buy these hinges.
Some of my recent work... All designed using Vectorworks.
Bruce Kieffer replied to Bruce Kieffer's topic in Solids Modeling
Here's a shop tour video of my shop made by The Minnesota Woodworkers Guild: https://clipchamp.com/watch/YHX2PrFXIFR -
I had renamed the none class. I have no idea why I would have done that. I found the "real" renamed none class, renamed that none, and all seems good now. Honestly, I think it would be best to not rename the none class. I can imagine a mess of bad things happening.
Vectorworks is telling me this class of mine is a default class and I can't delete it. How do I make it NOT a default class?
Electrical Switches, Outlets, and Cover Plate symbols?
The Receptacle tool is very basic. All I can do is apply a different color or texture, and make simple modifications in the tool's settings dialog box. -
Attributes palette missing at Vectorworks start?
Bruce Kieffer replied to Bruce Kieffer's question in Troubleshooting
My workspace was created in 2023. This problem was fixed (for me) with a system update. -
I have to think the need is limited to a small number of Vectorworks users who would make use of "real" woodgrain texture mapping to justify Vectorworks allocating engineering resources to create the tool or method. I would love to see it though. I imagine it would work like this: Apply a woodgrain texture to an object, then define the grain direction. Vectorworks takes care of the rest.
And what about end grain! I've often wondered who decided 24 hours was enough time for a day! I would need more if I spent my time wood grain texture mapping every surface of kitchen model.
I gave up trying to apply wood grain texture to Vectorworks models long ago. It's too hard to make the grain run the way grain runs in real wood, and it seems that no matter what you do the color rendered in Vectorworks is never the color you want. Instead I use shaded rendering and a wood tones color palette that I created. Red oak for this return air grille: Red oak cabinets and a maple table:
Subtract Solids is not available for some objects?
I figured it out. Destination layer has to the same as the layer the objects are on. -
Bruce Kieffer posted a question in Troubleshooting
I have two objects in the same class and on the same layer, but I cannot use them together to subtract solids. If I paste them into a new file, then I can use them together and subtract solids. What is wrong? -
I haven't been too concerned about this since I retired, but I think that it was fixed or at least improved in newer version of Vectorworks.
- 5 replies
- rendering
- renderworks
(and 1 more)
Tagged with:
I have a second display too. And now that you mention it, my resource manager (undocked) also is invisible all the time. -
Does anyone else have this problem? I boot Vectorworks and my attributes palette is invisible. Window/Palettes/Attributes is checked, but the palette is invisible. I uncheck and recheck that command, and then the attributes palette appears right where it should be.
Created 3d loci is not visible?
Hum... That is the setting I am using, and Select Similar DOES select 2D loci, but NOT 3D loci. I tested in a blank document too. OK, I tested some more. It takes a bunch of clicking to "hit" the 3D loci in some spot different than just highlighted to get the Select Similar tool to select them all. -
Yep! That's the solution. Now I have to delete all of them that I placed trying to make it work!!! Thank goodness for the select similar tool, but darn that does not work on them, but custom selection does. -
What might be stopping Vectorworks from placing a 3D loci in my file? The 3D loci works on a blank document.
It's the jambs that I can't make work. I modeled this window. It does what I need. I realize my illustration needs are different than an architect's.
