Kieran
    13
Everything posted by Kieran
  1. Ability to add bullet points and that the text affected by the bullet point stays in line withe the bullet point indent
  2. Exactly. Or clipping a wall layer while leaving the interior layer intact. Or clipping a the exterior casing on a product while leaving the interior parts unclip.
  3. Ability to create multiple Renderworks Textures at once. Possible by dragging and dropping multiple images onto Resource Manager Renderworks Textures window or through a dedicated menu
  4. Ability to do hidden line render while using a Clip Cube
  5. Please add the ability to selective place Worksheet rows on a Sheet layer.
  6. Is it possible to add the ability to choose the layers that the Clip Cube affects?
  7. Is it possible to add the ability to choose the layers that the Clip Cube affects?
  8. Tried it. No difference. Still lots of white bounding boxes representing symbols. Luckily they are not appearing in sheet viewports but its making it difficult to work and preview.
  9. Hi i am having the same issues as symbols appearing as white boxes on active layer plus those from invisible layers. Vw22 sp3
  10. I have been using VW2017 on a macbook pro with 16GB Ram for 2 weeks. It has crashed every single time I have quit even if I close the drawing first. This also means it won't remember the settings so I have to keep telling it not to show helpful dialogue boxes again and again.
  11. Thank you Alan. Just downloaded your improved and simplified version and had a play. Love It. Great to learn something new. Cheers Kieran
  12. Hi Alan Thank you to everyone who responded. Its the first time I have posted and I did not expect a responce. Attached is the object I have been working on. Its a frame with an artwork that may be useful to any exhibition designers out there. The frame, glass and matt board are all textured using the Apply Texture node. I had hoped to be able to use a Texture Map node of some sort to control the texture map of the artwork in the frame. Instead the way forward seems to be to wrap the network, ungroup the each frame the network produces and adjusted the artwork texture map. I would love any comments on improvements on the network. Also can anyone tell me where to find the node Ordered Points. I found it in a tutorial but can't find it in the list of nodes definitions. Cheers Kieran Marionette-Frame_2.vwx
  13. Hi I would like to be able to apply a texture to an extrude so that it matches the width of the extrude. Also need to be able to edit the orientation. I have tried the Set Texture Size node with no luck. Cheers Kieran
