David E.Labovitz
    4
Everything posted by David E.Labovitz
  1. Stephan -- I guess my problem is mostly getting the opening triangles so hinges will go in the right places. Thanks, Dave.
  2. How does one insert bifold cabinet doors? Thanks, Dave.
  3. When I draw a new cabinet (using Cabinet 3D) it has two sides, top and bottom. But all are of arbitrary thickness, in my case .787 (20mm) . The same thing happens for cabinet doors. 1 -- I'm using 18mm plywood. How do I set a default that will specify .709 (18mm) v. .787 ? 2 -- Cabinet door overlays and offsets are also preset. How can I change these? 3 -- If I need to reconstruct files, which ones and how? Thanks, Dave. Vectorworks 2021 SP5, Interiorcad 2021 F2.1
  4. Sorry, but can you be a bit more explicit about what to do with XG Resources/Configurations/Miscellaneous to enable opening triangles? I tried changing DoorTriangle from 0 to 1 but that doesn't appear to have done anything. Is there any documentation for any of this? Thanks, Dave.
