filip
32 -
Posts posted by filip
Dear enthousiasts
When I export a drawing to the VW given pdf formats the results a not that good, especially when you zoom in; see Sht 1.
If I export only one drawing it looks fine; see a3
Is this what you all do, don't place to many drawings on one sheet?
Those drawings are exported to PDF/A-1b
Sht 1 plattegronden situatie .pdf
regrads
Filip Bosscher
Thanks for your advices; I tried all of them, but it didn't work.
I tried exporting the vw into other 3d formats, like 3ds, kml, igs, sat, stl and stp
it worked fine.
Could it be that fbx needs some special settings?
regards
Filip
@ VIRTUALENVIRONS: I will try this, thanks; do you know how to convert the 3d model to 3d polygons?
@ Pat Stanford, I try this also, yes and yes, the computer and the program where restarted.
@ zoomer: that might be a point, this is a rather difficult project and a big file, I don't know if that is complex for VW?
Filip Bosscher
Dear enthousiasts
I can't export my vw model to fbx, the exported file contains only 0 bites, so It remains empty.On my other master computer the fbx export button remains gray, and exporting to fbx is not possible at all.
Are there special settings needed or maybe a special workflow for doing this?
regards
Filip Bosscher
Vectorworks has a good working tool for connecting horizontal walls and components of walls,
was it to difficult to create a tool for vertical walls?
thanks taoist...I wil try to go with your flow.
I can't find a sollution for connecting / changing the individual setting of differentcomponents of a walltype vertically,
without affecting the whole wall type,
so is there a way to change the wallsettings of the components for an indiviual wall without changing the wallstyle completely?
best regards
Filip Bosscher
Thanks, I will try this
Dear Wes,
is there a tutorial for the use of Data Tags,
I can't find a Data Tag somewhere in the menus.
Filip
great thanks for your advice,
do you also have a idea for getting the individual height and width of a windowframe, in the worksheet,
when I choose "hight" or "width" the dimensies are multiplied bij the number of windos (also handy)
but a column with the actual dimension would be practical. See screenshot.
with the best regards,
Filip Bosscher
thanks....that simple and I couldn't figure it out
best regards
Filip Bosscher
Dear vw users,
I like t make the window id tag smaller in my drawings, but I can't find the path for that symbol.
Has anyone a idea?
best regards
Filip Bosscher
that's practical, thanks
filip
Thanks Pat,
that's a practical advise.
Filip
Is there somewhere in the forum a much more extended list of functions for making records?
greetings
Filip Bosscher
Dear users,
dos anyone know how to make anotations in a tumbnailview,
I would like to ad information in a frontview of a window.best regards
Filip Bosscher
Dear users,
I am creating a view using records for showing the windows of a project,
three issues I would like to solve:- in the front view of the window I would like to see the width and the height of the window
- or in the colom height or width I would like to see the actual dimensie of the window and not the sum total (I can't find that specific function)
in the colum comment I would like to write some additional comments, now this colum is still part of the database sheet!
best regards
Filip Bosscher
Dear users,
when opening the anotations in a sectionview I would like for instance use color for an anotation,
but the sectionview automaticly makes an anotation black.
Does someone knows how the operate the settings?
best regards
Filip Bosscher
Dear enthusiast,
does anyone has a instruction for making a list with images of the windows?
regards
Filip Bosscher
nurbscurve line can't change in a dashline?
in Architecture
Posted
dear users,
does anyone know how to change the grafics of a nurbscurve?
Filip Bosscher
