Frank Schneider
    5
Reputation
0 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. Thank you William - my VW became slow and laggy after my computer upgraded to Sequoia 15.6.1. This solved that issue too.
  2. OK, I'm working on adapting - It isn't difficult, just a change in mindset. That and having to actually think about the mechanics of it as I draw. Thanks!
  3. That did it. Thank you. I may have to reconsider my use of none class. I usually use it as my sketch layer, and then assign objects to a final layer once they are complete. Maybe not the most useful way, especially if I need to change the attributes of the label for each drawing via edit in the resource manager. I still don't understand why the OIP class doesn't override the class in the definition. Seems like that would be helpful, and clearly it did at one point, in previous years when I used the tool and everything worked the way I want it to.
  4. I have used the drawing label tool before, but for some reason now when I use it it seems stuck to none class visibility. No matter what class I assign it in the object info palette it behaves like the class is none. So I assign it to a different class (sides) but when I hide none class it disappears. I check and it still is assigned sides class, which is visible, but it acts as though it is assigned to none class for visibility. My old files work perfectly - the drawing label shows up with the class visibility it is assigned, not none, so seems to be happening now with new files. I also tried several different files and the behavior is the same. No matter what class I assign the label to it follows none class visibility. Using VW 2024 update 7 Spotlight on a Mac. Thanks for any help/suggestions! Frank Schneider
  5. Did you solve this problem. I am having the same issue. I am working with a file that has been imported from 2011. I've been adding lights to the standard plot. In '11 the channel and circuit hookups worked well. But now they don't sort right. I tried the alt_chan, and when I went back to chan it sorted correctly. But I cannot get the circuits to sort. When I try alt_circ the lights I have added since importing to 2013 show up with no circuit. And when I go back to circuit the new lights are at the top with no order. Help!
