808 -
Posts posted by Travis
Armstrong is mostly right. . .which is first cousin to being "mostly dead". (A reference to a very funny scene from the greatest movie ever made: Princess Bride)
Epson's drivers are considerably more accurate with color than the OSX GIMP drivers. Maybe not a big deal for most plotting, but a very big deal for my second favorite pasttime: photography. Also, we've not had any problem using non-Postscript printers or drivers with Vectorworks.
[ 01-13-2006, 12:44 AM: Message edited by: Travis ]
You can, however, delete a post by clicking on the edit icon (looks like a paper & pencil). If you remember to copy the body of the post, you can simply paste it into a post in the proper section.
Good luck,
You only create the external reference (from the working file to the "remote") once.
However, from any design layer (or several different layers) a Layer Link can be created that refers to the WGR'd layer (shown in italics). This link has the advantage of being rotated of moved around on the layer without reverting positions when the WG reference is updated.
You can also create any number of Viewports that refer to the WGR'd layer.
Good luck,
Kevin,
The Epsons simply stop printing and wait patiently for someone to replace the cartridge. It then continues without wasting any paper. The driver doesn't, however, send notice across the network that the printer is out of ink. . .so we all try to just listen or check on it occasionally to make sure everything's running as expected.
Eric,
I think I'm probably allergic to extended warranties, so view my comments accordingly. Seems like each one I've purchased has been a complete waste of money. I'd be more inclined to do a little research into the local Epson service center's turn-around time and qualified techs. We're fortunate to have a very good one here locally. A year or so ago, our 7600 was out of sorts: took one new ink pump, a nozzle and a general cleaning to get it back in shape. We hauled it to their facility (because they could get their inhouse tech on it one day quicker than the mobile guy) and had it back in two days. Cost $460. It's the only repair work we've had in more than three years and a couple miles of paper.
Good luck,
[ 01-09-2006, 06:44 PM: Message edited by: Travis ]
Eric,
We use an older G4 as the print server (it simply has Share Printer checked in the setup, nothing special) for our Epson 7600 (previously) and 9800 (current) printers. Have had zero problems so far as print queue, etc. are concerned. Occasionally have had mixups re paper size and ink out (stops printing untill someone notices and replaces a cartridge), since the big printers are in another room.
Good luck,
Craig,
You'll see by my signature that we're very comfortable using Epson's printers. Color is second to none and waterfast. Reliability has been at least 90% uptime and the 9800 handles 36" rolls. I've been very pleased over the years with the service we've received from our local EpsonPro dealer. Epson seems to take very good care of its Mac users.
One conderation not to be overlooked, however, is that everything Epson makes is a true "printer" rather than a plotter. They're simply not as fast. Clearly, we've decided this feature is secondary to others.
Good luck,
erona,
We were all newbies, once. Keep asking questions.
The folks with big numbers, like Kevin and me. . .we just had more questions to ask!!
[ 01-06-2006, 07:31 PM: Message edited by: Travis ]
Thanks, Armstrong, this tutorial is very helpful. Wonder if you might post it on the TechNotes/HowTo board.
Happy New Year!!
Try searching this board for threads regarding Hatch(es). I'd search both the general and the architect boards. I think you'll find quite a bit of information.
Just the reassure you, hatches are NOT easy. Sometimes they're not even straightforward. You might also check out VectorBits and VectorDepot to see if any of the available hatches will do what you need.
Good luck,
We keep a dynamic library of typical details drawn on separate design layers, grouped in files by type. FramingDetails.mcd, for example, has a few dozen individual details, each on its own design layer. There's also FtgFnd.mcd; Roofs.mcd; OpeningTrim.mcd; etc. You get the idea.
As CDs progress to the point where they're ready for details, you simply Work Group Reference the appropriate detail layers in. These external WGR'd layers are then referenced by Viewports and additional notations added, if any. When the CD set is complete, we "break" the WGR link (making sure to check keep info from referenced file) so the details in the CD set don't change with future updates to our typical library. Breaking the link also enables drawing specific changes to be made to the imported "typical" detail(s) as needed.
As new details are created, we often add them to the appropriate library file so they're easy to find should they be needed again.
Describing it is almost more work than reality.
Good luck,
[ 01-05-2006, 10:43 PM: Message edited by: Travis ]
Also, make sure the crop's Class is turned on. . .for the Sheet (from the main menus), not just for the Viewport. If the Class is set Invisible or Greyed, you won't be able to select the crop. . .even in the Crop mode.
One good reason to make sure you have a Crop class and that all crops are set to that class when first created.
Good luck,
Jeffrey,
It's been this way since 11.5.1. The tools rely on the Class setting for the Sheet, including inside Annotations, while visibility relies on the Viewport settings. It is a bit quirky.
Sorry I didn't see you post earlier. . .I might have saved you some time and grey hairs.
Good luck,
Are you aware that VW will create automatic dormers? Just select a window PIO (Plug-in Object) and insert it into the roof. Your editing options, once inserted in the roof, are somewhat limited so you may end up redoing it a couple of times. But the roof-to-roof geometry will be correct every time.
If the above doesn't produce what you're looking for, I would be "building" the dormer walls on the roof using the Wall PIO and then angling one end of the wall to match the roof pitch. Use the 3D edit tool while viewing the dormer wall in elevation. Then I would "build" the dormer's roof using either the Create Roof tool or by creating the individual Roof Faces.
Since the method of construction of a dormer is to build it over the main roof (commonly called "overbuilt") either before or after the opening is cut out, it might help to think in terms of how it would be constructed. The dormer roof simply butts to the main roof.
Good luck,
It seems there is a Command-key to switch offsets off and on. Perhaps you're invoking it inadvertantly. I'm away from my office, so don't have the manual. . .I believe there's a table of Command-keys in one of the appendices.
I've never had autosave turn itself off. What system are you on?
A window object could be a Plug-In (would normally be parametric, which you're looking for) or a symbol. The symbol could be static (it was built with extrudes and shapes and then converted to a symbol) or could contain a plug-in object.
If it's a window plug-in object (PIO) that's been put inside a symbol, just double-click to enter the symbol (or command-[ ). There you can modify the PIO and, upon exiting the symbol (command-] ), all instances of the symbol will be updated.
However, if it's a symbol the Object Info Pallet (OIP) should indicate symbol rather than PIO.
Perhaps you mean window object, which would indicate Plug-In on the OIP. I'm unaware of any window plug-ins that aren't parametric (adjustable from the OIP), but they could certainly exist.
Good luck,
quote:Originally posted by Robert Anderson:So you can think of it as a "trick by design".
I think, Robert, I'm going to start using that line with some of my clients. At least the one's that like the design!!
Thanks for your continued help on these boards.
Are you saying that the font prints correctly in some places but is replaced (with the light font) in others? On the same sheet? Or at least in the same file?
I've not heard of this happening before. I'd make sure the font is geniune TrueType (TT). I'd also search this board for other posts regarding fonts. . .you'll find several.
It would be helpful to know which OS (and VW version) you're running. VW uses system fonts and is very sensitive to corrupt font files. Nearly all font issues stem from using poor or corrupt fonts.
Good luck,
1) Make sure the None class is marked Use at Creation as well as 2) the class in use (your 'circuits' class in your example). 3) Then make sure the Attributes Pallet shows that the object is referencing the class styles. It seems you're doing 2 & 3.
I should have mentioned the None class anomaly above. It's puzzled me since I discovered it (with Peter's help, I believe). . .but if it isn't marked Use at Creation, other classes will less reliably apply class attributes to both new and existing classes.
Good luck,
For all those wondering, Armstrong took years of "greek" to be able to speak it so fluently. Perhaps someone else might try their hand, but I'd interpret the above into English as "class attributes aren't bullet-proof because of the complexities involved."
All kidding aside, in addition to the quirks described by Viper, we've learned that as a file gets more complex, Class Attributes become less reliable. I don't remember ever losing a previous class setting, but I can predictably create a situation where reassigning an object to a new class does NOT result in the object taking on the new class' attributes. Despite what appears on the Attributes pallet. (The pallet shows the new attributes, but the object doesn't!)
Guess that doesn't help you "solve" the problem, Viper, but at least you know you're not alone.
With any luck, we'll get someone from NNA to weigh in here.
Good luck,
I think there's far too much respect going on around here!!
Merry Christmas to all. . .
David, do you use the Issue Manager? If you click the right settings, it will insert file name and current date on every sheet or only on selected sheets. Giving you the option not unlike Kevin describes.
[ 12-13-2005, 11:09 PM: Message edited by: Travis ]
What version of VW Architect will you be using in your classes?
Please see:
http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=16;t=001800
http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=38;t=000002
Slightly different descriptions of the same protocol.
Good luck,
[ 12-12-2005, 10:50 AM: Message edited by: Travis ]
Jim,
We have stored wall-styles for our typical footings (10x20; 10x24; 12x30; etc.) and foundation walls (heights can be set from the Object Info Pallet). In our library, we have a number of pier Symbols which are typically made up of a Floor (for the footing) and a Column (to extend above grade). These get dropped in as req'd. There is the Drilled Footing plug-in tool that will take care of circular piers.
We always use the Frame Floor from Polygon tool. After it's done, go in and add the appropriate double joists, etc. You can even show hangers where appropriate.
It might be helpful in the future for you to include your OS and the version of VWs you're using.
Good luck,
Mac Compatible Plotters
in Troubleshooting
Posted
Eric,
I'll be anxious to read of your experience with the HP. Especially how easy it might be to get set up and running.
I'll point out that while we run the 220ml cart's, some of the colors only get changed every 6 months or so (ie, magenta) while the two blacks seem to last only a week. Never had any problems with a cartridge being in the slot for an extended time.
Good luck,
