Sbd
    501
Posts posted by Sbd
  1. Not sure if this is possible, but i wanted to post it here first. I love the feature where symbols can be scaled proportionally to itself in order to provide the correct size of lettering for paper scale. One of the things that I do on my drawings is create a 1:1 scaled symbol, and then scale them proportionally to the drawing size. That means, if it is a 1/4"=1'-0" drawing - i scale that symbol 48 times - to get the same appearance as i would at paper scale.
    One of the many benefits of this feature is that I can share this with engineers or other architects that use Autocad. Unfortunately, when symbols are inserted in annotation, the drawing itself has to be exploded and scaled back again in model space. This is why the scale feature id design space is so useful.
    Here is the question - I want to do the same with a data tag tool - precisely for the same reasons. Currently, I've desiged a 1:1 tag and use it in annotation space. If I were to use it in Design layer space - i would have to again - scale appropriately - after I have inserted them. Is it possible to have an option to create the tags at a certain scaled size - IE 10x, or 12x etc...?
    Wonder how others do this. I know this is a new feature, but it has certainly opened a totally new world for us in terms of parametrics, so way to go VW, couldn't love this data tag tool more!
    • Like 2
  2. Hi everyone,
    I've been going through the forum, and can't seem to be able to find information on how to reference resource tags in worksheets? The one great thing about the new data tags is that now they can reference any geometry, material, symbol or group with record information placed on them. However, when you want to strategically use that information in a worksheet and lets say the object is a symbol or a group, we have to create new records for the object take-off just to isolate say, plumbing from FF&E, to ceilings, railings, lighting symbols, etc... currently there is no way of doing this without calling out all objects with the same record format or strategically calling it out by object type (things start to get complex when several object types are referenced by symbols category)
    question 1 - Since material take-offs have been created in VW symbols, is it possible to add an object type category? That way, future symbols created by the community can be shared using the same record format, and used in worksheets by isolating the object types?
    question 2 - can resource tags (not data tags, but the tags imparted on a symbol - with the add tag right click on the resource symbol object) be referenced in worksheets? (that is my potential workaround for symbols that already have the material take-off record format, but no category other than the tags)
    question 3 - is it possible to select symbols by folders in the database selection criteria? It can certainly help narrow down a lot of things, rather than selecting one symbol at a time as another possible work around.
    Thanks in advance!
  3. For some reason when i modify a ceiling grid element, i have to move the points twice, or rather the movement doesn't fully refresh for some reason.
    Can someone confirm please? If need be i can upload a sample.
    Just rechecked the problem - the problem only persists if it has a lot of edges. regular rectangular ceilings work right the first time. perhaps a memory problem?
  4. 4 hours ago, JMR said:
    And, if you set up a housekeeping window schedule that lists all windows regardless of the "include in schedule" setting, you won't accidentally miss any windows. I guess you could also pull up the window configuration data to the housekeeping worksheet and thus immediately see which is just an opening.
    I agree, that's a good idea
  5. One thing it to note - there is a limitation in the number of point you can see inside the model, so breaking it up into pieces is important. And also, make sure the scales match based on the laz file. sometimes the output from faro or leica cyclone (what i used) can be in a different measurement. The reason i know is that i ran into that problem.
  6. Don't know if this is possible, I didn't see an option for this in the general options, but is it possible to callout the gross wall area of a Wall and Cwall?
    On worksheets the tag is =WALLAREA_GROSS, but i can't seem to be able to use it or access it in the data tag dialogue.
    Preferably i would like to call out Wall, window, door and floor areas out in data tags (Building department requirements). Don't know if the same functions will work for the as well.
    Any ideas?
    Thanks in advance!
    • Like 1
  7. Hi All,
    Vectorworks 2019 permanently corrupted 2 files I've been working on in the past 5 hours. By the looks of it, there must have been conflicted information in worksheets and custom records being used by datatags. This happened when I modified a custom record from a worksheet linked to a datatag. In another case, i modified the record directly, and the program crashed. Don't know what the cause is, but afterwords, vectorworks wouldn't want to open the files again. This is very stressful, especially since I have a deadline. I will lose 5 Hours of work unfortunately due to this problem. 😖
    I've updated to SP v 1.2 prior to corruption. There was a consistent amount of crashing due to worksheet malfunctions. This is the first time I've had VW permanently corrupt 2 files. I can't seem to be able to upload it either, perhaps because I'm currently writing from abroad. Please let me know if there is a way for them to be recovered.
    Also, this is what the .lck file generated
    <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
    <FileLock>
      <FileLockInformation>
        <User>Samuel</User>
        <Computer>DESKTOP-D9T06VJ</Computer>
        <LockedTime>3624248431</LockedTime>
      </FileLockInformation>
    </FileLock>
    Thank you in advance!
  8. Hi all again,
    I'm trying to use a data tag with a custom record. A general length call out for the rectangle works, however a custom record doesn't show up when called out in a custom tag.
    As you can see below, data tag calls out for the custom record, but it doesn't show up when used.
    Maybe i'm doing something wrong?
  9. Hi Jeff,
    I was thinking about that too. Considering now that the new id tool can display a local callout, while at the same time the item can have a detailed specification on a separate record of the same object. Or, you can add them in a worksheet when calling out all items you wanted to specify out of all your records.
    But, i feel that option might be a bit too tedious.
  10. Hi everyone,
    Another questions regarding worksheet functions. Is it possible to call out which windows/doors are located inside a particular wall type?
    We generally need this information for energy requirements, and was wondering if something like that was available parametrically. I'm trying to call out wall style name, window ID, and door id and i get the following:
    is there a way to integrate wall style id and the objects located inside them using conditional statements in a worksheet?
    Also, is there a way to just simply call out a wall type id? I can no longer see that option in the 'records' drop down menu.
    Either way, thank you in advance!
  11. I tried doing that, but then the text gets unbearably large, and all the window menu items are also overbloated in size. Here are the things i've tried so far:
    properties settings - high dpi scaling override - system (enhanced)
    Lines are extremely blurry and interface is almost unusable. However, plugin settings work at full screen. The curser however is extremely small.
    Then with 200 % scaling (default settings, no system dpi alteration)
    The plugin settings at 200% barely fit, but at least theyre modifiable. However, user interface for windows (icons, etc..) are too small for the 15" screen
    With smaller resolution and default settings :
    Application is relatively stable, however top view is still blurry. Otherwise plugin settings work. The top plan view settings work best at native resolution, but plugin settings work best at 175% scaling or reduced resolution. Can't win here. 😕
    Will have to use option 3 as it is the best of all worlds.
    Thank you Jim for your help...If its possible though, perhaps this problem could be fixed in the future? meaning - allow scaling up to 225% (4k resolution on smaller screens)
  12. Thank you Jim,
    I can see the difference, but then the desktop user interface becomes way too unmanageable for proper use on a small 15" screen. Any other work arounds?
    I tried lowering the resolution, but then icons start to get blurry too....
  13. Ok, i'm starting to realize this might be a major bug. After downloading a resizing / windows moving application - for some reason the preview window elongates the top/plan preview no matter what i do. I tried resizing it with no avail.
    Any have similar problems on smaller screens?
  14. Hi Everyone,
    First time i ran into an issue because I started working from a laptop. I used a workspace that allowed for a higher resolution and all the window screens for doors, windows, data tags, etc... fit inside. Now that i have a lower screen size and import the same workspace, the windows dialogs extend beyond the screen. Any way of getting them to fit without changing the workspace?
    Note: window key + left / right works, but it doesn't resize the window vertically
    Thank you in advance!!
  15. Hi everyone,
    Noticed that the data tag is missing a few key features (unless i'm missing something). Is there a way to get Z value, or Z value above grade in a data tag tool? It would be wonderful to just call out the z value of a slab on the 2nd story to show what its elevation is above grade / datum. Is this possible?
    Thanks in advance!
  16. That plan as you can see isn't very simple either. Custom selection helps dramatically. In either case, I can't always wait for VW to help, but you can send the file to tech support, see what they can do, at least that's what i did earlier today.
    It took me all of 20 minutes experiment for the solution and another 10 to carefully modify the file.
    But trust me, I have a deadline this Friday myself, so I've been doubling down on solving this problem myself.
    Good luck in getting yours straightened as well!.
    • Like 1
