Yep... my pallets do the same thing. I'll bet you are correct - it has to do with two separate destinations that have different scaling. I do an OK amount of programing now a days, and it works great for setting up a show before I get onsite. I've pre patched and set groups and such in several airports on my way out to gigs and that touchscreen works very well as a software control surface. Also, its great for when I'm using Vision at home for small test modules. Super quick setup rather than having to get a console in the office.
As for this PIO I'm putting together - it works well in it's current state, but I moved around the parameters in the parameters hierarchy to display in a certain in the OIP, and it seems like the text that is entered in the dialogue box only updates the text in the first text parameter in the list from a hierarchical standpoint. I've attached the .vso to this post and here are the parameters as they currently stand:
Also, here is the code:
I thought I made an edit in your code that would pull the text from and update directly to 'CableTextDT', but that isn't the case currently. Any ideas? I'm sure I integrated the code incorrectly, but I can't figure out where I went wrong.
Thanks
Cable Break Test.vso
