Amorphous - Julian
    424
Everything posted by Amorphous - Julian
  1. Thanks Jim. Perhaps its worth starting the conversation with Chaosgroup? Revit already has this VRay plugin and users of Revit love it.
  2. Oh right! Thanks for that Andy. Don't know how we missed that one! Case closed for this then.
  3. One of the annoyances we find with the Titleblock Border object is that, in a multi-user situation, only one person can work on ANY titleblock. It would be ideal if different 'parts' of the titleblock can be checked out by different people. For example: I ask STAFF A to work on making sure 'Current Plot Date' - 'Auto - Short' is turned on for all sheets (more on this issue later**) And, I ask STAFF B to apply the latest 'Revision number' to ONLY the sheets we are issuing (more on this later too##) Because Titleblock Border is one linked object across all sheets, I can't have STAFF A and STAFF B doing the above tasks simultaneously. Would be nice if the Titleblock Border is somehow broken into parts so different people can do different things on different sheets at the same time. ----------------------------------------------------------------------------------- ** Problem with Automatically applying Current Plot Dates to sheets upon placement. Even though showing 'Current Plot Date' is set to show as 'Auto-Short Form' in my 'Titleblock Style', upon placing the titleblock on our sheet, the 'Current Plot Date' doesn't show up, and we have click into the PIO dialogue and manually turn that on for each titleblock we place in. This is very time consuming. ----------------------------------------------------------------------------------- ## Problem with applying the SAME information to MULTIPLE, SPECIFIC sheets Currently, we can only apply desired information such as 'Revision' to only 'ALL' or 'ACTIVE' sheets. I would be much better for us to be able to apply information to a list of drawings from a form that shows all drawing. Finally, I really don't understand why navigation of the 'Title Block Manager' is sequential (via the 'next button), instead of with a drop-down list. And why does clicking on the 'Titleblock manager' take you back to the first sheet, and not the current sheet you are working on. @Markus Barrera-Kolb fantastic worksheet. We have spent hours trying to figure out how to pull out these kind of data from the Titleblock border but in the end settled with only showing the 'current plot date' and 'current revision'.
  4. We do use separate classes for each finish (GL01, GL02 classes for different types of glass... TL01, TL02 classes for different types of tiles). In fact, the above elevations were generated by the 'walls components' picking-up up on the different 'renderworks texture surface hatches' of the relevant 'class renderworks texture' (a long, round-about way of achieving 'wall surface hatch by class') Yes- we can use unstyled walls with two 'finishes components' on either side of the wall, but it doesn't resolve the issues of the 'start and stop' and having still to define two different 'finishes components' on either side of the 'core wall'. It becomes the same multiple small, short walls as described.
  5. 01 THE ISSUE WE SEE: Wall tool works great for larger projects where 'wall types' are standardised to a limited number of variations. But in smaller, bespoke projects where two sides of walls have a lot of combination of finishes (think 'bathroom on one side, bedroom on other' ... etc), the number of wall types required to reflect these conditions gets out of control. See enclosed images: One one side of the wall (see SIDE 1.png), we have a timber veneer finish bordering an adjacent mirror. Even though the other side in both these finishing conditions are both paint finish (see SIDE 2.png), we have to create two different 'wall types' for this. You can imagine how the different combinations of finishes can cause the wall types to spiral out of control quickly. Plus, there are a lot of 'starting and stopping' of walls- Whilst in real-life situation, this wall would be built as one continuous core in the centre. The other disadvantage of the current method (refer to the elevations) is, when rendered, a junction line that is supposed to separate the finishes would not appear in elevation. So, in order to show any kind of construction gap or joint between the two walls, we'll have to make yet another wall type, with a thinner 'component' that sets back from the finished surface, and we'd call this 'gap wall' In other words, if we want a 5mm shadow-gap between the said mirror and the timber wall, we'll leave a 5mm gap between the two said wall types, and fill the gap between the two walls with a 5mm long 'gap wall'. This is not really a feasible way of building a BIM model. 02 THE SOLUTION WE WOULD LIKE TO SEE: On a construction site, the 'core' (stud, masonry...) of the wall is always constructed first, and then the 'components' (gypsum, stucco, plywood...) are applied over them. Importantly, the 'core' is constructed continuously. It would be most helpful if 'WALL TOOL' is just the walls- giving us the ability to draw continuous 'core' walls, without 'stopping and starting' the walls to accommodate the finishes components. If 'WALL TOOL' draws continuous 'Core Walls', there should be a 'FINISHES COMPONENT TOOL', where users can create 'Finishes Build-Up' styles that can be 'snapped' onto the 'Core Wall'. This way, we can stretch the 'Finishes Component' along the surface of a 'Core Wall' long as it needs to be, and even have the option to add 'skirting, flush skirting, cornices' or the like to finish them off. To resolve the issue of displaying junctions between adjacent 'Finishes Components', perhaps we can be given the option to 'show/hide joint between Finishes Components', or even have the option to add trims between them. This concept would work great if the Doors and Window objects can intelligently penetrate these 'Finishes Components'. The final point we would like to say the above method can be advantageous because it will allow each 'Finish Component' to be automatically tagged with a 'Finishes Tag'. This can be done by picking up on the properties of each 'Finishes Component'
  6. Clip cube is a great tool. But if part of the design is not perpendicular to X and Y axis, the shortcoming of the tool surfaces. We tried using 'rotate plan', then activating the clip-cube. Unfortunately this doesn't get around the issue. It would be good if you can 'select' the Clip Cube and rotate it (in plan) to the desired angle.
  7. @Jim Wilson can you kindly answer this? Have you guys explored this with Chaosgroup?
  8. How about moving more tools and tasks to support multi-core processing? has this been realised yet?
  9. I second this! Has nemestchek/Vectorworks had any conversations with Chaosgroup?
  10. Just want to revisit this topic... lots of firms outsource to India if they use AutoCAD/Revit... do any Vectorworks firms do the same? If so- I would like to get some details of them.
  11. Hey guys... have we found the cause? I'm experiencing the same problem and would like to know how it was resolved?
  12. Hey Tim. I second this post. No idea how it is to be used either.
  13. Hi Diogo, all those issues you have raised are valid but can be resolved by planning the model differently (as Christian as pointed out) 1) If the first floor has a wall, and the second floor also have a wall, then just draw them as two different walls 2) You can overcome this by doing an extra 2D layer with Dotted lines that you can turn on and off. But I agree that this is very frustrating! 3) You can show the wall components in Section, but it takes a long while you get all the wall components set up correctly. And Christian, I agree with you on that may key elements is missing from Vectorworks. As an ARCHITECTURAL tool, some important tools that Diogo pointed out sorely missing. Furthermore, working on a model as a team presents a nightmare. ArchiCAD has many good points, but it has a bad interface for 2D drafting, and is more expensive. Revit does't run on macs. So Vectorworks, rather being the best choice, is the product that happens to fill in a particular void in the market. We'd love to see it being developed as a more meaningful collaborative tool.
  14. Hey guys... just wondering whether this post should get further updates... or just let it died? I think it is an important conversation. Blimey- has your office resolved the speed problems by switching back to design layer referencing? Jeffery- I second Blime's point about 'workflow'. If you have more than one person working on a project, the task of modelling has to be spread between different people in the team. In any case, modelling+drafting are intertwined processes. It is not like when you finish modelling, you start drafting. These two processes are very much interactive and iterative. All the other CAD packages on the market now have much better teamwork interfaces (look at ArchiCAD, Revit etc), they also have a teamwork structure that keeps the model in one file to maintain its BIM integrity. Vectorwork's ability to link one file to another a really antiquated way of teamwork. Is Nemetschek planning a better, and different way of teamwork for Vectorworks?
  15. Hey what is it like to use VW2011 with the Quadro FX 4800 graphics card. Are the renders superfast? Does open GL respond really quickly? I have an early 2008 8 core mac pro with the standard ATI Radeon card and EVERYTHING is VERY SLOW. Hope to hear form you. Julian
  16. Agreed. This is important to the workflow of architects.
