Triadd
    12
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    architect
  • Homepage
    www.triadd.nl
  • Location
    Deventer, The Netherlands
  1. I noticed the same thing and learned from Julian Carr that this is a bug. He suggested as a "by-pass" to create a circle, use the dimension circle tool (yes that works o.k.) and reset the arc length in the Object Info palette to the desired length. Not to elegant but it's a way to get there. ------------------ Triadd, buro voor architectonische vormgeving
  2. Thanks for th reply, I'll try a litlle bit harder (did you use any lubricant oil ? :-))) and I'll check the Editing Palette ------------------ Triadd, buro voor architectonische vormgeving
  3. yes, and for me it had something to do with customized paper sizes. I could not use my former (MiniCad 7.0.3) sizes so I redesigned them in VW9. I'm plotting to file (.plt. files) so I don't know about problems with Ink-Jets etc. ------------------ Triadd, buro voor architectonische vormgeving
  4. yes, and for me it had something to do with customized paper sizes. I could not use my former (MiniCad 7.0.3) sizes so I redesigned them in VW9. I'm plotting to file (.plt. files) so I don't know about problems with Ink-Jets etc. ------------------ Triadd, buro voor architectonische vormgeving
  5. I just got a mail from Carl Haynie who experienced the same problems. According to a tech.rep from MicroSpot one will have to upgrade to Microspot Graphic Pak to solve the problems with VW9. I'm still waiting for a response from MicroSpot. regards, Jan W.Henssen
  6. Could someone teel me what I' doing wrong : (VW9 on PPC G3 MacOs9.04) 1-- Double click on the Rectangle Tool does not open a "Create Rectangle" box 2-- Double click on the Line Tool does not open a "Create Line" box 3-- Interior and Exterior Radial Dimensions do not work on Arcs 4-- Where is the Trim Tool Has this all changed since VW.8.5 ?? Would appreciate any thoughts,idea's kind regards, Jan W. Hensssen
  7. When hitting the RevisionCloud Toolbutton I get a message saying that the PIO is not installed. I found a RevsionCloud VectorScript (K.vss) in the PlugIn folder but how do I get this to work as a Tool ? Any help appreciated, regards, Jan W.Henssen
  8. I can not get the exterior and interior Radial Dimensions Tool to work with Arcs or parts of Circle Segments ? Any idea's ? Thanks and regards, Jan W.Henssen
  9. After upgrading to VW9 I get an error message (ERROR 11) when I try to save a file as plotfile with MacPlotPro. Which version of MacPlotPro is compatible with VW9 ? All suggestions welcome. kind regards, Jan W.Henssen
  10. quote: Originally posted by Caleb Strockbine: With the release of VectorWorks 9 and VectorWorks ARCHITECT 9, VWA has become a fully integrated package rather than an add-on. VWA version 1 won't work with VW 9; instead, you should upgrade to the VectorWorks ARCHITECT 9 package. Call the Nemetscheck sales team for more information. I'm sure you'll be able to return your VW 9 package and replace it with VW ARCHITECT 9. Thank you very much for this fast reply. I will certainly contact Nemetschek on this matter ! kind regards, Jan W. Henssen ------------------ Triadd, buro voor architectonische vormgeving
  11. I just installed V.W. 9.0 and R.W. 9.0. Somehow my 1.0.1 version of V.W.Architect does not seem to be recognized by V.W. anymore. When clicking op Architect set-up assistant I keep getting a message to register. But I can not find a way to put in my registration number !! Any advice much appreciated. kind regards, Jan W. Henssen
