About This File
This object is a result of working with @TSG-Sim on a challenge where a popup was to control both the color of an object as well as text.
The method behind this is to combine smaller lists into a larger list to easily distribute the values. I used a Point 2D node in this example, but you could use any other list handling that you would like.
What's New in Version 1.0.0 See changelog
Released
No changelog available for this version.
