Lin Posted August 26, 2000 Share Posted August 26, 2000 I am unable to render a fasica on a dormer to match the roof fasica. It renders as a wrap of the shingles. Has anyone solved this problem? Quote Link to comment
Guest Posted August 29, 2000 Share Posted August 29, 2000 Lin: Unfortunately this is a new bug that you have discovered. Although we thank you for that we have no work-around at this time other than using working planes to create 3D polygons and attach a new texture or attribute to that. It has been placed into the bug list and will be worked on so that a solution will be brought out as soon as possible. ------------------ Brian O Nemetschek North America Technical Support [This message has been edited by Brian O (edited 08-29-2000).] Quote Link to comment
Ken Fisher Posted September 7, 2000 Share Posted September 7, 2000 You can always trace the shape in front view and extrude it to a small thickness then, in plan view, drag it to be just in front of the dormer fascia. Render this shape to whatever material you wish the facsia to be Quote Link to comment
