eric.rktek Posted November 30, 2005 Share Posted November 30, 2005 I'm working in V12 now, and I have a graphic question regarding Cased Openings. When I put a cased opening in a wall, there is a centerine that appears across the length of the opening. I've gone through the various options in the Settings button in the OIP, but can't seem to find a way to turn this line off. It also shows up when I print. Also, when I pull the opening out of the wall, it disappears. (I do have my jambs set to 0" thickness). In the past, the opening used to show as two lines so you could see it in the drawing. Does anyone have any suggestions? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted November 30, 2005 Vectorworks, Inc Employee Share Posted November 30, 2005 Set the jamb face width of your cased opening to 0.00001 in or mm. This should fix the problem. Quote Link to comment
eric.rktek Posted November 30, 2005 Author Share Posted November 30, 2005 Robert, Thanks. That fixed the problem. Quote Link to comment
