  • 6
Worksheets - the ability to select multiple objects via the worksheet
Anna Arbetter
4 answers to this question
On 3/8/2022 at 1:56 PM, Anna Arbetter said:
Worksheets:
  • Add the ability to select multiple objects from a worksheet, not just a single object from a single row.
  • I would use this in a “data editing/review/quality control” worksheet to select multiple objects for changing one setting at once for all the objects. One example, to select all Ash trees so that I can mark them as To Be Removed. (I realize there are other ways to select multiple things, such as the custom selection tool, but the worksheet is where I do a lot of review of the project).
I would like to add to Anna's request
1. Multiple Object Selected - Select All, not just the first. Then you could use the arrows in the OIP to move between them.
2. Discontinuous Selection - Either Select All, Or at least Select First
3. Summarized subrows - Either Select All, or at least Select First
4. Maybe offer options both to Select All and Select First as separate menu options.
