GetCellString returns unkown Value
Milan
Hello,
I imoorted a table (tried it with a tab delimited text file and with an excel table) and then I wanted to read a cell value from it through Marionette with Get Cell String. I hooked up the hWorksheet attribute to a Objs by Crit node and set nRow and nColumn to 1. The output is <UnknownValue> instead of the string in that cell.
I have tried everything I can think of: using different fileformates for the table, imputting different numbers for row and column, using the decrepet GetCellStr command instead of the normal GetWSCellString command. I don't know what else I can try.
The Handle Type that comes out of the Objs by Crit node is 56.
I am using Vectorworks 2021.
Help is urgently wanted.
