AhmedMuhsin Posted September 24, 2021 Share Posted September 24, 2021 hello, i dont know if this is the good forum to post my question. i would like to know how to install VW2022 silently in unattended mode? after extracting the Vectorworks 2022 Installer.exe i cant find the resources folder like older versions. best, Ahmed Quote Link to comment
AhmedMuhsin Posted September 27, 2021 Author Share Posted September 27, 2021 Any help? Quote Link to comment
MaScMVGM Posted October 21, 2021 Share Posted October 21, 2021 From the downloaded ZIP file you can run: resources\installer\Install Vectorworks2022.exe with paramter --help Good luck 🙂 Marc Quote Link to comment
AhmedMuhsin Posted November 17, 2021 Author Share Posted November 17, 2021 On 10/21/2021 at 2:21 PM, MaScMVGM said: From the downloaded ZIP file you can run: resources\installer\Install Vectorworks2022.exe with paramter --help Good luck 🙂 Marc Hi Marc, Unfortunately there is no resources folder after extracting the .exe installer. Ahmed Quote Link to comment
MaScMVGM Posted January 5, 2022 Share Posted January 5, 2022 Hi Ahmed, sorry for the long delay. The resource folder is a hidden folder. 😉 First of all, I unhide all hidden files and folders. Cheers, Marc Quote Link to comment
R3-IT Posted April 9, 2022 Share Posted April 9, 2022 There is no resources folder even with showing all hidden folders. Quote Link to comment
CRedman Posted May 11, 2022 Share Posted May 11, 2022 Did you find a way in the end? Having the same issues here. Quote Link to comment
WilsonFredonia Posted June 8, 2022 Share Posted June 8, 2022 I have had success doing a silent install with the following command in SCCM: "Install Vectorworks2022.exe" --mode unattended --unattendedmodeui none --Serial xxxxxxxxxxx At this point, I am now working on scripting the copying of the full library onto each of the lab machines. Hope this helps! Now for my ask, anyone have any luck on the Mac side of things...? Either the flags are completely different on the "/Volumes/Vectorworks2022-SP3-646432-SeriesBEG-installer1-osx/Vectorworks 2022 Installer.app/Contents/MacOS/Vectorworks 2022 Installer" Unix command, or they have completely borked silent install on Macs since the installbuilder.sh is now gone. Definitely many kudos if someone has some tips on that. Quote Link to comment
WilsonFredonia Posted June 8, 2022 Share Posted June 8, 2022 Oh and the other thing I forgot: you need to unzip the dist file with 7-zip and the /resources/install folder is in there that contains the correct installer file. Quote Link to comment
jwaltonen Posted June 29, 2022 Share Posted June 29, 2022 I expanded dist with 7-zip and ran "Install Vectorworks2022.exe" --mode unattended --unattendedmodeui none It installs a whole mess of stuff in the program files Vectorworks2022 folder, but the executable is not there, Vectorworks 2022.exe. Any ideas ? Quote Link to comment
