Dominic H.
Font keeps changing when text is edited
I was wondering if anyone has had this problem, and could maybe suggest a solution?
The default font that we use for our text is "BELL GOTHIC BOLD". However, whenever I select and edit a text object it converts into "BELL GOTHIC LIGHT". Once I have finished editing my text, I then have to go back and manually change the font back to the BOLD.
Any ideas/solutions would be much appreciated!
Thanks
Dominic
VECTORWORKS 10.5.1 on OS X 10.3.4
Yes. we are having the same problem in our office which uses 'universal'. The answer so far I got from tech is that our font is postscript font not a true type font. We did convert our font to true type but haven't had a chance to test it. If you do, let me know.
Dominic,
You are using a font that is not fully supported under OS 10 - most likely an Adobe MMX font.
You'll need to purchase the OS 10 version of the font from Adobe.
If you do have a compatible OS 10 font, the font suitcase is most likely corrupt or missing necessary components.
