Lynda Posted May 16, 2005 Share Posted May 16, 2005 I have used the change working plane to align to a vertical object. I have then tried to revert to the previous working plane (the ground plane) This works in top view but when I use the menu for the other views they still seem to refer to my created working plane. This also applies when I try to use the set 3D view command. I had previously been able to site a view from inside my model now, when I select this command and draw in my view line, the view created still seems outside of the model and I get get inside. It also looks in the opposite or apparently random direction when set diagonally. I have been using the working plane palette to no avail. Anyone any ideas to correct this please. Quote Link to comment
Lynda Posted May 17, 2005 Author Share Posted May 17, 2005 Cracked it. I've discovered that I need select the walk through tool for the set 3d view to work! I must have done it by accident befoer! Quote Link to comment
