D Wood Posted August 18, 2003 Share Posted August 18, 2003 I have suddenly lost the use of the door & window tools - they are still on the pallette, but when I click them, nothing happens. The mullion one is active, and all other tools seem to function properly. This is a file converted from VW8. I'm using VW10.1.2 on an iMac running OSX 10.2.6. Quote Link to comment
Guest Posted August 18, 2003 Share Posted August 18, 2003 Once you opened your VW 8 file in VW 10, did you run UPdate to V2 Objects command under the Tool>Utilities menu item? If not, you'll need to do that first. That will convert the door and window object types from VW 8 to the newer version of door and window objects for compatibility purposes. Quote Link to comment
D Wood Posted August 18, 2003 Author Share Posted August 18, 2003 1. No 2. Yes 3. It worked - full service is restored, thank you. Quote Link to comment
