Rodger Posted May 12, 2003 Share Posted May 12, 2003 How Is The Sample 'NW House' Perspective In Vectorworks Drawn? It Is A Single Line Model. How & Why Was This Done? Quote Link to comment
Guest Posted May 13, 2003 Share Posted May 13, 2003 The model was drawn using the wall tool, window tool and various other tools. THe model of the house you see when you first open the file is an isometric view of a lyer link rendered in hidden line rendering mode. It probably was switched to polygons or lines using the convert copy to polygons or lines command once the layer link was set up. Scroll thru the layers and you'll see the individual floors in 2d until you switch to a 3d model. Quote Link to comment
