Maarten DE Posted April 11, 2021 Share Posted April 11, 2021 Hi all Is anyone able to create Control Points on the fly? On this page (and also in the SDK manual) it's explained but I think this is some old code because I can't find any case of that switch (action) in the SDK. Quote Link to comment
Hippocode Posted April 12, 2021 Share Posted April 12, 2021 (edited) You can handle creation/deletion/position as mentioned on that page. Depending on how flexible this should be I do this on kobjectCreated event or in the recalc event. But for managing the images, displayed hover text and other specific actions I advice to use the IProviderCursorHandles interface. This also replaces the old code you mentioned. The interface will catch these events. Edited April 12, 2021 by Hippocode 1 Quote Link to comment
Maarten DE Posted April 13, 2021 Author Share Posted April 13, 2021 Thanks Wouter, the creation of the control points works now. A question: is it possible to have a custom data bar while dragging a custom control point? I tried this in a overwrite of VWParametric_EventSink::OnCursorEvent( ParametricMessage* message ), case message->fAction = ParametricCursorMessage::EAction::kAction_MouseDown: CustomBarRefID outCustomBarRefID; bool b = false; b = gSDK->CustomBarCreate( 1, outCustomBarRefID ); b = gSDK->CustomBarInstall( outCustomBarRefID ); CustomBarFieldInfo fieldInfo; fieldInfo.fFieldLabel = "Length"; fieldInfo.fFieldValue = 1000; fieldInfo.fIsEditable = true; fieldInfo.fIsLocked = false; b = gSDK->CustomBarSetFieldInfo( outCustomBarRefID, 0, fieldInfo ); // b = gSDK->CustomBarRelease( outCustomBarRefID ); It still shows the default data bar but all values are empty. When I don't use gSDK->CustomBarRelease() (because it returns false) the data bar values are still empty, except the first (X) has a reversed S in it... I tried the same in and overwrite of IProviderCursorHandles::OnCursorAction_MouseDown( ICursorHandleActionContext* context ) but that one doesn't even get hit (even when I remove the overwrite of VWParametric_EventSink::OnCursorEvent( ParametricMessage* message )). This doesn't work either. TXString lab = "Length"; gSDK->SetDataDisplayBarField( 0, barLength, lab ); gSDK->SetDimUserBarValue( 0, 1000 ); In the VWTool_EventSink class, I found these functions, but I don't think I should use them because the Control Points are part of the object, not the tool. Also, when I implement them, they don't get hit. virtual void OnCustomBar_Setup(); virtual void OnCustomBar_Setdown(); virtual void OnCustomBar_UpdateValues(); virtual void OnCustomBar_LockValue(size_t fieldIndex, const TXString& userString); virtual void OnCustomBar_UnlockValue(size_t fieldIndex); virtual void OnCustomBar_LockValue(const CustomBarLockValueData& lockData); virtual void OnCustomBar_UnlockValue(const CustomBarLockValueData& lockData); Did anyone got this to work in their PIO? Quote Link to comment
Hippocode Posted April 13, 2021 Share Posted April 13, 2021 (edited) I'm using the CParametricCustomBar wrapper class instead. This example comes from a cursor event that shows and allows to change the angle between two lines. I initiate it on OnCursorAction_MouseDown on first click fAngleBar.ClearFields(); fAngleBar.AddField("A:"); fAngleBar.SetFieldLock(0, false); fAngleBar.Create(); fAngleBar.SetUp(); fAngleBar.Install(); On any other click, within the same function I close it because what I was doing has completed. fAngleBar.Release(); while mousemove I modify the value to match the situation: gSDK->CustomBarSetFieldAngle(fAngleBar.GetCustomBarID(), 0, Utility::GetAngleBetweenVectors(-V1, VDir)); Edited April 13, 2021 by Hippocode 2 Quote Link to comment
Maarten DE Posted April 14, 2021 Author Share Posted April 14, 2021 Thanks again 🙂 . I did notice that in IProviderCursorHandles, all the OnCursorAction_ ... and OnCustomBarEvent functions only get hit when clicking/hovering/... over parameter control points, not the dynamic created control points. Strangely enough, the GetHandle... functions of that class do get hit when clicking/hovering/... over dynamic created control points. Has anyone notice the same thing? Quote Link to comment
Hippocode Posted April 14, 2021 Share Posted April 14, 2021 Think of the OnCursorAction triggers as a tool, you need to start it before the others will be triggered. And it starts with triggering a controlpoint by clicking/hovering it I guess. The other functions just show the images and text and decide if they should be visible, those are triggered constantly probably. I believe non parametric control points have positive index values, parametric ones negative. you can mix the use of them but it's important to return true/false properly @ IsDefaultCursorHandled Sint32 Index = context->GetCustomPtClientID(); // Index of CP I believe there are a lot of inconsistencies in those interfaces. For me I know that ICursorHandleActionContext::GetObject not always returns the effective object (or didn't in the past). For that reason I keep a copy of the handle in the interface itself and update it whenever GetObject does return a value in any of those functions. This ensures the other functions know which object we are managing the controlpoints for regardless of the provided context. 1 Quote Link to comment
