Editing plant lists
JEA
Once a plant list has been generated and added to a drawing can the "scheduled size" be edited in the spreadsheet without changing the value in the plant database. What I am trying to do is find an easy way to change the scheduled size from say a #3 container to a #5 container. Any input is appeciated.
Regards,
JEA
  • 2 weeks later...
From what I have gathered is that you should fix your scheduled size the first time you input the plant in that particular file. If you have used that plant a few times in the drawing and then want to change the scheduled size, you will have to change the size in the Object Info pallette for each plant occurrence. Click on the Data tab and scroll within the middle portion until you find the scheduled size. Once you haver changed it for each plant occurence, it will show up correctly on the plant list worksheet. This can be adjusted from file to file, but it has to be the same for all occurences in each file. If you have two sizes for the same plant in the same file, then use two different symbols for that plant and it will show up twice in the plant list. Hope this helps.
