FRED JOHNSON
lineweights
quote:
Originally posted by FRED JOHNSON:
Does VWA automatically assign lineweights to
objects, if so, can these be changed on the fly without screwing things up?
If you use the VA Setup it will assign LW via the pre-set class structure. You can change the LW of any singular object (or selected objects) via the attribute pallette. Alternatively you can change the LW by changing the class attributes and every object with that class would change.
I recommend the latter to avoid screwing things up (which I do often <grin> ).
