ErichR Posted February 27, 2006 Share Posted February 27, 2006 V12 and 12.0.1 crash upon trying to make a class invisible, or when tyring to delete a certain class. Is this a possible bug, or can a corrupted file cause this response? Quote Link to comment
Guest Posted February 27, 2006 Share Posted February 27, 2006 Erich, Does the same thing happen in a new document? What error message did you recieve? Are you using Mac or PC? Quote Link to comment
ErichR Posted February 27, 2006 Author Share Posted February 27, 2006 Seems to be isolated to a single file. Once, there was an out of memory message when trying to process a final quality Renderworks. "...encountered a problem..." message usually. WXP Dual core 4GB RAM Quote Link to comment
Guest Posted February 27, 2006 Share Posted February 27, 2006 What type of crash/error message do you get when you go to delete a class? Quote Link to comment
ErichR Posted February 27, 2006 Author Share Posted February 27, 2006 "...encountered a problem..." message usually. This file is a v11 legacy, and is fairly complex. It was somehow corrupted before, resurrected through a workgroup referencing workaround, and since starting this thread, resurrected yet again. (Resources were upgraded to the current version.) Maybe the question should be, why is the file corrupting? It's a bit annoying for the time it takes to straighten things out. [ 02-27-2006, 07:59 PM: Message edited by: ErichR ] Quote Link to comment
Guest Posted February 27, 2006 Share Posted February 27, 2006 It's likely the file corruption did not get completely cleared when using the workgroup referencing option. I suggest sending the file to tech@ where we can peel the drawing down in an attempt to find the problem, fix the file and send it back. Quote Link to comment
ErichR Posted February 28, 2006 Author Share Posted February 28, 2006 Wow. That would be a great service. But I'm torn between thinking that the WGR band-aid approach is working (and the need to use the file), and the probable need to get this fixed. What would the turn-around time be? Quote Link to comment
Guest Posted February 28, 2006 Share Posted February 28, 2006 Erich, It depends on how bad the file is, but we can usually have something back within one business day. Quote Link to comment
