David Ormsby Posted November 27, 2005 Share Posted November 27, 2005 Just getting started with VW 12 here - and I've run into something wierd with the Drawing border tool. I've always created/used a custom template with my layers and classes set up - anyway, in this process I tried inserting a new drawing border on a blank sheet layer, and I get an error message "The size is not found in the data file". If I click the Preferences, everything is set to 0. I can ignore the warning, add the DB (which appears as ASME A size, even though the page prefs are set to letter) and then make it fit through the OI window. But this isn't what I saw demoed at LDI or in the Upgrade Companion. any thoughts? thanks Quote Link to comment
Guest Posted November 27, 2005 Share Posted November 27, 2005 In VW preferences (Tools>Options>VW Preferences), click on the Session tab. Do you have "Display Minor Alerts on Mode Bar" check marked? What happens when you use a new, blank document? I can't duplicate the error you are getting with a new or VW 11 converted to 12 file. [ 11-27-2005, 11:15 AM: Message edited by: Katie ] Quote Link to comment
Guest Posted November 27, 2005 Share Posted November 27, 2005 Are you using an old workspace from 11, or are you using one of the 12 standard workspaces (or a modified one) ? Quote Link to comment
David Ormsby Posted November 28, 2005 Author Share Posted November 28, 2005 I'm using a modified version of the 12 spotlight workspace. I just tried using the original spotlight and stndard workspaces and got the same error... Quote Link to comment
David Ormsby Posted November 28, 2005 Author Share Posted November 28, 2005 I did have Minor Alerts checked, but no difference. New blank doc gets the same error - this happens as soon as I click on the DB tool. What is the "data file" the error is refering to? FYI, I still have 11 installed (giving myself a month to transition). Would that matter? Quote Link to comment
David Ormsby Posted December 1, 2005 Author Share Posted December 1, 2005 Katie Any further ideas as to what steps I could take to fix this? Thanks Quote Link to comment
Guest Posted December 1, 2005 Share Posted December 1, 2005 David, What are the drawing units for your template? Tom Urie Nemetschek, N.A. Quote Link to comment
David Ormsby Posted December 1, 2005 Author Share Posted December 1, 2005 Tom Feet and Inches Quote Link to comment
Guest Posted December 2, 2005 Share Posted December 2, 2005 David, I failed to notice in your original post that the drawing size was ASME A. This is a known problem that the drawing border will fail when being placed into a drawing when the print area is either 11 x 8.5 (ASME A) or 8.5 x 11 (Letter). What you need to do is after the border is placed, use the OI palette and change the Size to ASME A. If the print area is 8.5 x 11, you will also need to change the orientation to Portrait. Of course, you could also change the print area to something other than Letter or ASME A before inserting the drawing border. Tom Urie Nemetschek, N.A. Quote Link to comment
David Ormsby Posted December 2, 2005 Author Share Posted December 2, 2005 Aha - I do use ASME A a lot, most of my clients want something that fits in thier notebooks (the paper kind!). Don't go to larger sheets till later in the game. I take it this is on a "to be fixed" list? thanks Quote Link to comment
