ErichR Posted September 15, 2005 Share Posted September 15, 2005 The 'Elipse' command, after it's executed, calls it an 'Oval' in Object Info. Is it possible to draw an elipse? Is there some other way to draw an true elipse, and to dimension it? Quote Link to comment
MullinRJ Posted September 16, 2005 Share Posted September 16, 2005 An Oval in VW is an ellipse. If you convert it to a Polyline, it becomes an approximation using Bezier Curves. If you rotate it, it becomes a Polyline. What do you need to dimension? Major and minor axes are easy. Foci can be found with a little math. Raymond Quote Link to comment
