Matthias Veen Posted August 31, 2005 Share Posted August 31, 2005 When I try to cut an oval by half with the clip tool the complete oval disappears. Cutting an oval by half with an overlapping surface using the clip surface command doesn't work either. (VectorWorks 11.5 Mac) Quote Link to comment
Guest Posted August 31, 2005 Share Posted August 31, 2005 Try to use the split tool (split by line mode) or draw a line at the clipping point and use the trim tool. Quote Link to comment
