tgm
Editting 3D objects........?
Why can I edit some objects using the OIP and not others?? It seems if I create an object using add/subtract solids I cannot edit them , ie length ,width, height etc.
When the object type shows up un the OIP as an extrude I also have the same problem. I thought I would be able to just grab a corner and go but that is not the case with all 3D object types.
Am I missing something???
Tom in PA
Win XP
Ray,
11.5.0.4....
Just loaded the latest 11.5.1 last night but have not had a chance to try it out.
Tom
If I understand the problem correctly, I think there's a fix in 11.5.1 for editing extrudes in the OIP. For objects created with add/subtract solid you would double click to enter the solid, then edit the base object or objects used for add/subtract.
