Short lines selection to delete
archiwaner
Hi everyone!
I was recently asked how could one get rid of the shortest lines of an imported DWG drawing. After some searching, I could only find the advice of someone pointing to a Marionette solution. After some self teaching I want to share this little wrapper which, once turned into a menu command, deletes the lines from a selection which are shorter than one drawing unit.
On the one side, job done! On the other side, I have a little wishlist that maybe someone could help me with. I would like this tool to be able to:
- manually select the length for everytime the command is executed
- work in a way which is more graphic, i.e. not a menu command
- work also for older versions (I tried exporting to 2016 without success)
Thanks in advance for your insights / comments !
maxLength_1 unit.vwx
