Developer Wiki and Function Reference Links Read more... ×
Labar
Vectorscript to export VW file folders to .dwg (Mac)
Hi,
I use VW for Mac, I need to transfer all of my files to .dwg format in order to start using another software, Rhinoceros.
User points a folder->VW files in this folder are opened, one by one-> For each file, do the following commands: --->Open file---> export to .dwg format in the same folder
-->Close de file.
I guess its basic script, any idea if something like this already exists ?
Thanks
Edited by Labar
I could write the applescript I needed;
One more thing to solve, I am stuck pointing the 'Export DXFDWG' in my VS script.
It may be very simple to you
PROCEDURE ExportActiveFile;
BEGIN
DoMenuTextByName('Export DXFDWG',0);
END;
Run(ExportActiveFile);
http://developer.vectorworks.net/index.php/VS:DoMenuTextByName
http://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix#menu
Edited by Ibrahim
Seems like I am having the exact same issue as in this topic.
I checked the internal references from the apendix, I tried to use the command DoMenutextByName with other references like 'Print', it works, and none of the 'Import DXFDWG' and 'Export DXFDWG' work for me.
My conclusion is that the function is not working on mac ?
Any workaround? can this be done with a Python Script ?
Thanks in advance
Edited by Labar
