Martin Crawford Posted May 15, 2018 Share Posted May 15, 2018 I figured out how to scale a viewport, now I want to position it correctly. The following works: vs.SetObjectVariableReal(vpHandle, 1003, 32) #scale The following does not work: vs.SetObjectVariableReal(vpHandle, 1024, 0) # x vs.SetObjectVariableReal(vpHandle, 1025, 0) # y I get the following error message: Error: SetObjectVariable failed with constant 1024. This typically due to the operation being not supported for the passed object handle. As far as I can tell in the documentation, setting the x and y should be the same as setting the scale. I can't seem to figure out why one works and the other doesn't. Thanks Martin Quote Link to comment
MullinRJ Posted May 15, 2018 Share Posted May 15, 2018 Martin, ObjVars 1024 & 1025 are marked as READ-ONLY. Try getting the Bounding Box to find out where it is, then use HMove() to move it to where you want. The difference between the desired point and the existing point is the amount you need to move it. HTH, Raymond Quote Link to comment
relume Posted May 16, 2018 Share Posted May 16, 2018 Hello perhaps this snippet from a larger script may help: # -- create viewport : move viewport object to page center vs.Layer(vLayerViewPort_name) # selects layer with ViewPort object vViewCenter_x, vViewCenter_y = vs.GetOrigin() # this works as long SheetLayer origin was not altered vViewPort_Rect_center_x, vViewPort_Rect_center_y = vs.HCenter(vViewPort_Object_handle) vViewCenter_x = vViewCenter_x * -1 vViewCenter_y = vViewCenter_y * -1 vDifference_x = (vViewCenter_x-vViewPort_Rect_center_x) vDifference_y = (vViewCenter_y-vViewPort_Rect_center_y) # message("object_process_item : vViewCenter : " + str(vViewCenter_x) + " / " + str(vViewCenter_y) + " | " + str(vViewPort_Rect_center_x)+ " / " + str(vViewPort_Rect_center_y) + " | " + str(vDifference_x)+ " / " + str(vDifference_y)) vObject_type = vs.GetType(vViewPort_Object_handle) if ((vObject_type == 122) or (vObject_type == 3)): vs.HMove(vViewPort_Object_handle, vDifference_x, vDifference_y) best regards Quote Link to comment
Martin Crawford Posted May 16, 2018 Author Share Posted May 16, 2018 This makes perfect sense. Thanks! I still don't fully "Grok" the Vectorworks API. Sometimes things are straight forward and other times it seems convoluted. I will keep working at this and hopefully one day I will be able to answer a few questions. Again, Thanks Martin Quote Link to comment
relume Posted May 16, 2018 Share Posted May 16, 2018 Hello I complete agree with you. I feel all about the same. 🙂 Quote Link to comment
Martin Crawford Posted May 16, 2018 Author Share Posted May 16, 2018 MullinRJ How do you know they are read only? When I look at the appendix I see the following: Scale 1003 REAL ObjectVariableReal Viewport x Position 1024 REAL ObjectVariableReal Viewport x Position 1025 REAL ObjectVariableReal I don't see anything that would indicate 1024 and 1025 are read only. Where do you find that nugget of information. Thanks Quote Link to comment
MullinRJ Posted May 16, 2018 Share Posted May 16, 2018 Martin, IFF [sic] you really want to GROK the whole VectorScript experience, you'll have to procure a copy of "Hitchhikers Guide to All Things VectorScript (and Python, too!)." However, it may be a bit easier to download a copy of the SDK from the VW site: http://www.vectorworks.net/support/custom/sdk/sdkdown and look for this file: .../SDK/SDKVW(build#)/SDKLib/Include/Kernel/MiniCadCallBacks.h In it you will find long sloppily typed lists of extremely esoteric and somewhat arcane factoids. When you find yourself standing precisely in Ra's shadow, notice the following illuminations: const short ovViewportXPosition = 1024; // double read only - the X coordinate of the viewport on the sheet layer - Public for VS const short ovViewportYPosition = 1025; // double read only - the Y coordinate of the viewport on the sheet layer - Public for VS That is how I know 😉 If this doesn't help, ... Raymond Quote Link to comment
Martin Crawford Posted May 16, 2018 Author Share Posted May 16, 2018 Wow! Nice reference! Not related, but a long time ago I have a VW bug. I found a book on VW repair. This book was so well done that at 14 I rebuilt the engine one a 1969 classic VW. It ran for years. I wish I had the same book for VW & Python scripting. Every step seems like a slugfest. I've been banging my head against the wall all day trying to get viewport centering to work correctly. Using the following code: Quote for selectedObjects in range(0, len(objectList)): vs.Layer(ModuleLayer) # make sure we are on the correct starting layer screenName = objectList[selectedObjects][0] # Gets the Screen Name - 1st item in t = (screenName,objectHandle) objectHandle = objectList[selectedObjects][1] # Gets the Object Handle - 2nd item in t = (screenName,objectHandle) # Get the object height, width and bounding box of object p1, p2 = vs.GetBBox(objectHandle) objectWidth = vs.HWidth(objectHandle) objectHeight = vs.HHeight(objectHandle) #Create VP Crop Object vs.Rect(p1, p2, objectWidth, objectHeight) vpCrop = vs.LNewObj() # Create the layer and set the layer name layerHandle = vs.CreateLayer('01', 2) # using 01 forces the next unused sheet nubmer to be used layerName = vs.GetLName(layerHandle) # get they layer name. It appears the layer name is the sheet number vs.SetObjectVariableString(layerHandle, 159,'Module Layout - ' + screenName) vs.Rect(0,0,10,10) # test to see if something draws on the sheet layer #Create the VP and set Crop Object vpHandle = vs.CreateVP(layerHandle) vs.SetVPCropObject(vpHandle, vpCrop) vs.SetObjectVariableReal(vpHandle, 1003, 32) #set scale to a default of 32 viewPort_X, viewPort_Y = vs.HCenter(vpHandle) print(viewPort_X, " ", viewPort_Y) vs.ReDrawAll() viewPort_X and viewPort Y are always 0. What is super strange, is when I run the script it leaves me on the last sheet layer created and I can see a viewport created at 0,0 (with a red x through it). If I change sheet layers and change back, the viewport shows up in the wrong location. You can see the two attached screen shots to see what I am talking about. I've tried adding ReDraw and ReDrawAll in multiple points in the code and it makes no difference. I'm using 2108 sp3. It seems like some type of reset or redraw is required after the VP is created or maybe after the crop is set. Any thoughts? Martin Quote Link to comment
MullinRJ Posted May 16, 2018 Share Posted May 16, 2018 Gotta run, but I have 1 quick thought and no idea how it will affect viewports. Have you tried ResetObject()? This is a lot of what programming is about when you are learning, and after 30 years scripting with MC/VW I'm still learning. When in doubt, try something, anything, and take notes. Good luck, Raymond Quote Link to comment
relume Posted May 17, 2018 Share Posted May 17, 2018 Hello I am using my script for producing many small plats in a batch (moving window on every object) to export each to its own pdf for many years - first in VectorScript and now ported to Python. It works without problems. I do not need to ResetObject() nor ReDrawAll(). In general I do not see any greate difference to your code. The only difference in my script is, that I am using a predefined presentation layer and reusing it for every plat to be drawn and exported. But I do not think that this is the problem. I tried and slightly adapted your code (see attachment) and the only proble that I can see is, that vs.CreateVP() creates a ViewPort-Object with no layer and class activation (they are all set to invisible). So running your code I get also this square with the red cross in it. But when I assign class and layer visibility to active for this ViewPort-Object the bounding box of the viewport change to its real dimensions and location. Thus assigning class and layer visibility is "indispensable" to get the correct result, although the square with the red cross seems to be a temporarily "artifact" with a viewport with all classes and layers set to invisible. Finally the new created viewport has to moved to the page center (or any position) - that is default and is corresponding the manual viewport creation. best regards viewport.vwx Quote Link to comment
Martin Crawford Posted May 18, 2018 Author Share Posted May 18, 2018 I finally got it working. I'm not sure why, however a ResetObject was needed after the layers and classes were turned on. Thanks for pointing me the right direction. For some reason this was tough to get working. Again, Thanks! Martin Quote Link to comment
relume Posted December 5, 2018 Share Posted December 5, 2018 Hello With VW2019 I came across, that in my example file "viewport.vwx" the Python-Script "with visibility" to generate a ViewPort and to assign to it the layer visibility to active will crash VW2019. If the created ViewPort is manually deleted VW2019 will crash. So in the loop to assign the layer's visibility to active a condition has to assure, that the visibility is only set to design layers (many thanks to D. Corpataux from ComputerWorks.ch). So in the attachment there is a new stable Script named "with viability stable VW2019". best regards viewport_v2.vwx # python-script : "with visbility stable VW2019" import vs def createviewport(ModuleLayer, objectHandle): vs.Layer(ModuleLayer) # make sure we are on the correct starting layer # screenName = objectList[selectedObjects][0] # Gets the Screen Name - 1st item in t = (screenName,objectHandle) # objectHandle = objectList[selectedObjects][1] # Gets the Object Handle - 2nd item in t = (screenName,objectHandle) # Get the object height, width and bounding box of object p1, p2 = vs.GetBBox(objectHandle) objectWidth = vs.HWidth(objectHandle) objectHeight = vs.HHeight(objectHandle) #Create VP Crop Object vs.Rect(p1, p2, objectWidth, objectHeight) vpCrop = vs.LNewObj() # Create the layer and set the layer name layerHandle = vs.CreateLayer('01', 2) # using 01 forces the next unused sheet nubmer to be used layerName = vs.GetLName(layerHandle) # get they layer name. It appears the layer name is the sheet number #vs.SetObjectVariableString(layerHandle, 159,'Module Layout - ' + screenName) vs.SetObjectVariableString(layerHandle, 159,'Module Layout - ' ) # vs.Rect(0,0,10,10) # test to see if something draws on the sheet layer #Create the VP and set Crop Object vpHandle = vs.CreateVP(layerHandle) vs.SetVPCropObject(vpHandle, vpCrop) vs.SetObjectVariableReal(vpHandle, 1003, 32) #set scale to a default of 32 ## set class and layer visibility to viewport object vClassNum = vs.ClassNum() for vClassNumIndex in range(1, vClassNum+1): vs.SetVPClassVisibility(vpHandle, vs.ClassList(vClassNumIndex), 0) vLayer_handle = vs.FLayer() while vLayer_handle != None: vLayer_Type = vs.GetObjectVariableInt(vLayer_handle, 154) #Design Layer or Sheet Layer if vLayer_Type == 1: # Design Layer vs.SetVPLayerVisibility(vpHandle, vLayer_handle, 0) vLayer_handle = vs.NextLayer(vLayer_handle) viewPort_X, viewPort_Y = vs.HCenter(vpHandle) print(viewPort_X, " ", viewPort_Y) ModuleLayer = "test" vs.DSelectAll() vs.SelectObj("(ALL)") vs.Group() vGroup_handle = vs.LSActLayer() createviewport(ModuleLayer, vGroup_handle) vs.HUngroup(vGroup_handle) 1 Quote Link to comment
