PeterT Posted May 12, 2004 Share Posted May 12, 2004 If I draw a rectangle on top of a vertical line such that the line extends past the rectangle at both the top and the bottom, and with the rectangle selected and the line deselected, choose the "Trim" command, the rectangle cuts the line where it crosses it at both the top and the bottom of the rectangle. If you do the exact same thing with a wall drawn vertically instead of a line, when you trim with the rectangle it only cuts the wall at the top of the rectangle and fails to cut it at the bottom. This is not consistant with a wall drawn horizontally. If you trim a horizontal wall with a rectangle, it cuts at both the right and left where it crosses the wall. This seems to be true in both versions 9.5.3 and 10.5.1 Is this a bug? Regards, PeterT Quote Link to comment
PeterT Posted February 8, 2007 Author Share Posted February 8, 2007 ...and with version 11.5.1 and 12.5. I guess nobody trims walls with rectangles except me. But could the bug be fixed just for me then? Quote Link to comment
