Working drawings
Architect0139
1 answer to this question
This is already possible, select the section viewport, then click "Advanced Section Properties" in the Object Info Palette. In the Attributes tab enable "Separate Cross Sections" and check Use Attributes of Original Objects. (this should allow showing the 2D fills for solid objects) Then under the Display tab, check "Show Wall, Slab and Roof Components."
[img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=15530&filename=Screen%20Shot%202016-06-07%20at%2012.33.49%20PM.png[/img]
