Dubman Posted May 9, 2016 Share Posted May 9, 2016 when I use the custom tool to make a text tool for certain type of text on a certain class everything works except the class. When I make other objects, like a rectangle, it make the rectangle to the correct line type, weight, & color and on the correct class. Should the custom tool always select the class as per the settings to include the selected class, or is this different for each type of object used with the custom tool? Thanks Quote Link to comment
