Cloud Hidden Posted June 6, 2003 Share Posted June 6, 2003 Things aren't happening as I expect them to. What's a better way. Have a round wall and wanna create a bow window in it--5 windows total in the bow. Use the window symbol from the sampler resource file, set it to a perfect 90 degree orientation for the building, and change its width to 4'. The question is...how to best place the other 4....2 on either side with perfect spacing? If I use the same symbol, I have to change the width on each. I tried the Symbol Pick-Up mode from the 2D Insertion Tool, but clicking on the window in the wall gives message saying that's not a 2D Symbol. Tried Duplicate Symbol in Wall tool, but that wants to measure from the end of the wall, and I want to offset from the existing symbol. Am I overlooking a tool, or the way one of these tools works? Quote Link to comment
Cloud Hidden Posted June 6, 2003 Author Share Posted June 6, 2003 With more experimenting, it seems the Duplicate Symbol in Wall tool doesn't work on round walls, just straight. Is this a conspiracy against dome designers? Can you confirm it doesn't work on round walls? That makes it a nuisance to add a bank of windows following the curve of the dome... Quote Link to comment
Guest Posted June 10, 2003 Share Posted June 10, 2003 My guess is that it's a limitation. I'll look into it. A curved wall would require the window to rotate along the curve of the window. Since the duplicate symbol in wall works along a line, the curved wall poses a problem. When I find something out, I will let you know. Quote Link to comment
Cloud Hidden Posted June 10, 2003 Author Share Posted June 10, 2003 I agree it appears to be a limitation. VW already knows how to make the window follow the tangent when inserting one, so placing multiple shouldn't be toooo much of a stretch. It'd sure make bow windows easier to create, and I do that on almost every project. Right now, it's really painful to do. Quote Link to comment
