Vectorworks, Inc Employee PVA - Admin Posted January 24, 2017 Vectorworks, Inc Employee Share Posted January 24, 2017 From the FAQ: Can I convert a Project file back to a regular Vectorworks file? Yes and no. You cannot “convert” a project back into a regular Vectorworks document, but you CAN use File > Save a Copy As (Not just "Save As") in order to create a non-project version of the working file, which from then on will function just like a regular Vectorworks file. The original project can then simply be archived or removed at your discretion.NOTE: Make sure that when using Save a Copy As, you then select the VWX file format to save as, not the default VWXW format: Quote Link to comment
Seth Thomas Posted January 24, 2017 Author Share Posted January 24, 2017 Under File>Save A Copy As… you must change the file type at the bottom of the dialog box that appears. Quote Link to comment
